No turn signals; fuses OK ... ?
Old Apr 5, 2010 | 02:17 PM
abadinalbany's Avatar
abadinalbany is an unknown quantity at this point
Default No turn signals; fuses OK ... ?
Last week when the dealership was diagnosing my vehicle, "something" happened ... they said something about a blown fuse, but I haven't spotted anything blown. However, I've lost my turn signals. Headlights and running lights still come on, but no turn signals. No relay ticking, no signal lights lighting (I don't think). The 10A fuses under the hood for left/right signals all look OK.
There seems to be a ticking or humming noise coming from near the firewall on the passenger side ...
Old Apr 5, 2010 | 03:11 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
is their power to both sides of the fuses? Check it with your test light.
Old Apr 5, 2010 | 03:25 PM
Rogue's Avatar
Rogue is on a distinguished road
Agreed with Ryanmatt135.
Also, if you have a VOM, or anything that can check continuity, check the fuse itself. Have seen fuses that look good still be bad.
Old Apr 5, 2010 | 10:51 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
If it happened while they were in possession of the vehicle and actively diagnosing it, it's on them to fix it. I'd take it back and tell them you'd like them to fix whatever they screwed up.
Old Apr 5, 2010 | 11:10 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Do your hazards work? Flasher relay?
Old Apr 6, 2010 | 05:10 AM
Unfortunately since that day last week I took it to another garage to get plugs/wires/cap/rotor, secondary AIR pump, EVAP vent solenoid done, I'd guess they would reject my claim.
Old Apr 6, 2010 | 05:11 AM
Will check today on hazards. Like I said in the first post though, I don't hear the relay ticking ... but it might not be getting power, right?
Old Apr 6, 2010 | 05:12 AM
All two (four, I think?) turn signal fuses look good though.
Test light?
Old Apr 7, 2010 | 06:07 AM
ha soooo ... hazards don't work. turn signals do. the dealership apparently flipped the hazard switch and left it in the on position ... pushing it back down, turn signals work fine.
so, where do I look to troubleshoot the hazards?
SubbinBlazer
May 24, 2013 12:56 PM
nineteensixtycaddy
Sep 12, 2010 08:54 PM
deltas69
Mar 20, 2009 10:04 PM
mendez918
Mar 3, 2005 11:42 PM
blazin97
Feb 22, 2005 01:49 AM
