No vacuum to actuaor
Old Apr 16, 2017 | 05:26 PM
Steveo123xxx17's Avatar
Steveo123xxx17 is on a distinguished road
Default No vacuum to actuaor
hi I am new to this forum
I am having a vacuum issues with my 02 chevy blazer ls. There is no vacuum getting to my 4wd actuator. I have already replaced the TC motor. Checked and replaced vacuum lines. Installed new cable to differential
also replaced TC vacuum switch. I can hear clicking sound from TCCM. I was wondering
is there a vacuum solenoid switch somewhere?
Or is there a bigger problem going on?
I forgot to mention I have a 4.3 vortex engine
and have 3 switches on dash
2w hi. 4w hi and 4w lo
any help to resolve this problem is appreciated
I am vacuumed out of ideas
Old Apr 16, 2017 | 08:19 PM
AJBert's Avatar
Are you getting vacuum TO the TC vacuum switch? Also, is the vacuum line plugged into the accumulator in the driver's side fender? If so, it might be time to tear down the passenger side axle and tear into the front dif to find out if that is the problem.
Old Apr 16, 2017 | 08:31 PM
thank you AJ
I was hoping it wasn't in the diff
I will double check for vacuum
i will keep you informed
hoping for a oversight
Old Apr 17, 2017 | 07:08 PM
AJBert's Avatar
Could be something as simple as not connecting the three hoses to the TC vacuum switch correctly also.
Old Jun 7, 2017 | 10:52 PM
WinnipegsonomaZR2's Avatar
WinnipegsonomaZR2 is on a distinguished road
Have you tried to manually engage the 4x4 by hand.....I would try this as if you get to engage then good news is that it's not your front diff....funny thing is I took out my actuator today and found a tiny tear causing me my non engaging 4x4
Attached Thumbnails No vacuum to actuaor-img_0108.jpg   No vacuum to actuaor-img_0109.jpg
cjb2145
18
Oct 6, 2018 04:46 PM
Blazonaire
Dec 23, 2015 02:03 PM
Bberry20
Oct 27, 2009 02:44 PM
fzr confused
Mar 30, 2006 12:38 AM
doom1701e
Sep 8, 2005 09:16 AM
