Noise Problem 2000 Blazer 2dr 4x4
Old Nov 19, 2008 | 09:08 PM
el8232's Avatar
el8232 is an unknown quantity at this point
Default Noise Problem 2000 Blazer 2dr 4x4
I have a 2000 2dr Blazer 4x4and I'm getting a medium to loud roar (low pitch) from the rear end area at about 65 to 70 MPH. No vibration. New tires. Any ideas what might be causing this? I don't know if it's wheel bearings, differential, u-joints, etc. I don't know where to start.
Old Nov 19, 2008 | 09:10 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: Noise Problem 2000 Blazer 2dr 4x4
did it do it b4 the new tires???
Old Nov 19, 2008 | 09:20 PM
WolfPack's Avatar
How do you know its the rear end?
Old Nov 19, 2008 | 09:32 PM
el8232's Avatar
Yes it did make the noise before new tires. The sound is comming from the back of the vehicle. New wheel bearing in front also.
Old Nov 19, 2008 | 09:46 PM
WolfPack's Avatar
Roars are usually wind or tire related. A whine/clunk/screech is usually an axle.
Check your weather stripping and vents in the rear?
Old Nov 19, 2008 | 09:53 PM
2002XTREME's Avatar
to check the u-joints get under the truck and grab the driveshaft near the rear yoke and see if it has play in it, not around wise but up and down back and forth side to side if ya know what i mean by that.. for rear bearings jack up the rear from the middle with a safe floor jack get both wheels high enuff off the ground get in it put it in geear and slowly let the wheels start to spin see if ya hear the noise that way..I`m pretty sure if ya dont have posi someone can hold the left rear wheel still while the right rear rolls, if ya dont hear nay noise have them let go of that wheel and see if the noise starts..also how many miles on it? when the truck is on the ground and you put it in gear do you hear any clunks, ya might even hear like a ping noise if the u-joints are bad..try those options and post back..
Old Nov 22, 2008 | 04:27 PM
el8232's Avatar
Turned out to be U-joints. Replaced them noise is gone. They didn't have any play in them but they were very corroded. Nice quite ride now!!! [sm=happy046.gif][sm=happy046.gif][sm=happy046.gif]
00chevy
Mar 18, 2013 06:38 PM
i<3myblazer13
Mar 25, 2011 10:11 PM
blackblazer00
Jan 3, 2011 03:35 PM
pquada
Jan 13, 2009 02:54 PM
