Noobie here. Need some help, 95 Blazer
#21
You havent tried a free repair before you went and spent over a hundred bucks on a tune up?
Try the free stuff first!!!
#22
Where did you see I spebt 100 bucks? Ive only spent maybe 40 bucks on plug wires and egr gasket.
Anyways I did pop the vaccum line out, truck ran better but still rough with the vaccum hose off, I plug it with my thumb and the truck bogs back down and sounds same as before.
While I had the hose off I sprayed a quick squirt of carb cleaner down there, engine revd, put vaccum line back on, sprayed carb cleaner around the connections of the vaccum line and couldnt get it to rev. It revs fine with no sputtering or anything, just wont idle.
#23
You had said you bought plugs, found a bad wire (So I assumed you replaced the whole set) and normally if I go through the trouble of replacing plugs and wires, I also replace the cap and rotor.. My bad for assuming you replaced all the ignition components.
#24
I must have mis-typed, I never bought plugs, brand new ones were in when I purchased it. I replaced all plug wires, I did ordera cap and rotor from Rockauto(which wont be here till tommorrow).
Gotta run to the fedex store and Im going to go see if I cant figure this PITA out.
#25
Ok after I few people saying to check the injector spider, I got bored and pulled the intake off.
This was the result
This was the result
![](http://i23.photobucket.com/albums/b397/imguessingurgay/DSCN0332.jpg)
#26
Looks like you found your problem!
#27
yup the sensor thingy is connected to the bottom of the tube that goes to the air filter I remember when i put new thermostate in I took it apart to have more room to get to the thermostate... yup yup yup good luck feller your in a good spot lots of people will help you here so no worries enjoy later
#28
dude that was soo wierd I was going to write some thing and it ended up on someone elses post strange then I gave a little advice and figured my way back her hahahhahhah
ya dude the thing in your hand goes to the aparatas that goes to the air filter on the bottom of it I remove mine to get more access to the thermostat when I was replacing it ...
Good luck bra
Good luck bra
#29
![](http://i23.photobucket.com/albums/b397/imguessingurgay/DSCN0346.jpg)
![](http://i23.photobucket.com/albums/b397/imguessingurgay/DSCN0345.jpg)
![](http://i23.photobucket.com/albums/b397/imguessingurgay/DSCN0344.jpg)
![](http://i23.photobucket.com/albums/b397/imguessingurgay/DSCN0343.jpg)
![](http://i23.photobucket.com/albums/b397/imguessingurgay/DSCN0342.jpg)
![](http://i23.photobucket.com/albums/b397/imguessingurgay/DSCN0341.jpg)
![](http://i23.photobucket.com/albums/b397/imguessingurgay/DSCN0340.jpg)
And heres the puddles in the upper intake.
![](http://i23.photobucket.com/albums/b397/imguessingurgay/DSCN0339.jpg)
#30
![Icon Couchhide](https://blazerforum.com/forum/images/smilies/icon_couchhide.gif)
![Icon Playing](https://blazerforum.com/forum/images/smilies/icon_playing.gif)
![Icon Urinal](https://blazerforum.com/forum/images/smilies/icon_urinal.gif)
![Icon Speaker1](https://blazerforum.com/forum/images/smilies/icon_speaker1.gif)
