Is this normal? (Transfer case related)
Old Apr 19, 2020 | 09:32 AM
BorderCougah's Avatar
BorderCougah is on a distinguished road
Default Is this normal? (Transfer case related)
Hey guys.
So in the adventures of my fuel lines and the issues I had with them, I opted to remove my rear drive shaft to lower the transmission. In doing so, the tailcone of my transfercase began pissing fluid from the moment I removed the shaft from it's Internal Slip Yoke. Looked like Transmission fluid, so I'm assuming it is Transmission fluid that was in the transfercase. Except it honestly looked bright and new, yet my transmission doesn't show any loss on the dipstick (The amount lost was pretty substantial imo before I slipped the driveshaft back into the yoke to stop the fluid).
My question thus is threefold:
What fluid did the transfercases on these Blazer's typically use? Just the same as the transmission or was it a special fluid?
Does the transfercase and transmission 'Share' Fluid in a way, or are each self-contained?
Is it normal for fluid to have poured out the tailcone of the transfercase on removal of the driveshaft, or does that indicate a bad seal?
Thanks.
Old Apr 19, 2020 | 11:36 AM
Thanks.
I believe the automatic (4-button) case takes a special auto-trac fluid. The regular ones take automatic transmission fluid.
Both are self-contained and sealed from each other.
Yes, totally normal. There's a special "butt plug" to keep that from happening.
Old Apr 19, 2020 | 12:01 PM
Mine's a 3 Button. NP242 If I'm not mistaken, so looks like just nomal fluid. Good to know, and to know they're self contained. I'll look into refilling the lost fluid then. Weird to see thats normal though. I owned a Jeep Grand Cherokee with I'm pretty sure the same Transfercase (Again, the NP242) and it never did that, but I guess there could be differences between the transfer cases in the vehicles beyond Mechanical vs Electronic.
LannyL81
Aug 27, 2014 06:15 PM
tony991
Aug 22, 2011 07:30 PM
republic
Sep 2, 2009 09:56 PM
lennyblazer
May 7, 2007 07:38 PM
medion42
Mar 16, 2006 10:18 PM
