not sure if its arcing from my coil!
i havnt tried the water yet but does someone know if you should beable to see ANY sort of sparking from coil at night? i know what arcing looks like but this looked like i could simply see the blue light from the coil spinning inside the case but its a black case dont seem likely! ive also had problems with misfires and no start during damp weather and just tonight had a constant miss and ran crappy and light was flashing! might of finally found my problem but wana make sure you cant see your coil spinning in the dark through the case! and it was only a certain part where the casing meets up with the square thing running through the middle!
shotnva777
08-26-2011 11:31 AM
matt92
05-01-2011 04:39 PM
Peel01
07-24-2010 10:46 PM
DSMayo
03-15-2010 07:21 AM
