Noticed water dripping out of the psgr side floor vent..
Old Dec 30, 2010 | 11:31 PM
contour1's Avatar
contour1 is on a distinguished road
Default Noticed water dripping out of the psgr side floor vent..
most obviously heater core.. also leaks/drips behind the psgr tire.. you can see the slow drip.. Verify that it is Heater Core..? 2002 4.3
Problem has been there for a year or more.. but today, while checking for any leaks after replacing freeze plug..i found one.. drip drip drip.. came inside and ran the air... a/c ran fine.... heater didnt.. ran warm a couple of seconds and stays cold now.. engine stays at 160/170.. water is leaking.. but sooooo slowly.. still eventually the leak will drain the Rad.. so.. to make a long post longer.. i checked the vents.. driver side.. ok.. but passenger had a small trickle/ drip running out.. floor mat was wet where the water had ran..used to keep a shamwow!! under the floor mat.. and in the summertime it stayed dry 75% of the time.. so what ya think.... Heater core?? I put K&W in the engine to seal any leaks from the freeze plugs.. will it help here??
Old Dec 31, 2010 | 12:07 AM
ABN31B's Avatar
my thoughts are much like yours... a bad or plugged core.
supported: here
as for the K&W, i cant weigh in on that
does it smell like coolant on the floor?
Old Dec 31, 2010 | 06:43 AM
Definitely sounds like a leaking core. I'd fix it. I wouldn't recommend the use of stop leak ever, but that's just me.
Old Jan 1, 2011 | 12:51 AM
contour1's Avatar
" does it smell like coolant on the floor?"
no.. and the reason why is.. that it's had a slow leak for awhile and i've just finally gotten around to patching/replacing/fixing the problem.. so it's been running mostly water!! Just drive back and forth to work.. 5 miles.. but now that i have acheived the exalted status of Unemployed PC Tech.. I have all the time I need..so I'm fixing everything from a to z
Old Jan 1, 2011 | 01:33 PM
ABN31B's Avatar
well... at least you're putting water back it
As for the job... I know a company that is hiring PC techs in your area... (shameless plug)
Old Jan 1, 2011 | 06:27 PM
contour1's Avatar
Stopped it at the source today.. took both hoses lose from the firewall and connected them together to make a bypass.. results.. no runs, no drips, no errors..
Old Jan 1, 2011 | 10:44 PM
imsoraymond's Avatar
imsoraymond is on a distinguished road
i recently bought a 2000 blazer and the previous owner told me the heater core was bad, but i still have heat. it smells like antifreez when the heats on, but theirs no wet spots or dripping. and no matter what setting i put the air on( defrost, regular, feet ,etc.) it comes out all the same it doesnt make a difference. could this be a reult of a bad heater core or something else.
Old Jan 1, 2011 | 11:06 PM
ABN31B's Avatar
sounds like a combo core/blend door. search em up. plenty of info on both.
Old Jan 3, 2011 | 04:36 AM
contour1's Avatar
Default check it out
ah.. buts thats how mine started out.. very little grew into a problem
banshee386
Apr 5, 2010 10:57 PM
BlazinJay84
Dec 6, 2007 08:00 PM
Sunshine Coaster
Oct 14, 2007 03:21 AM
Matty Kling
Oct 10, 2007 01:25 PM
junkmonkey
Sep 18, 2007 06:37 PM
