obd I or obd II ???
Old Jul 28, 2009 | 06:36 PM
rowe's Avatar
rowe is an unknown quantity at this point
Default obd I or obd II ???
im trying to read the codes from my blazer,,but not sure
if its obdI or obdII,,the door sticker says it is 05/95 so
i would think its a 95 model.if not,is there a way to jump
obdII and i have tried to read with a obdII scan tool
it wont read it for some reason.
any help very much appreciated,,,thank you.
Old Jul 28, 2009 | 06:43 PM
Biohazed's Avatar
its ODB 1.5 .. its a one year only system they did when they did the switch to ODB II you need a scanner that can read both ODBI and ODBII to pull the codes
Old Jul 28, 2009 | 11:16 PM
rowe's Avatar
thanks biohazed,,,any good recomendations
on a not so expensive brand or model?
Old Jul 29, 2009 | 01:12 AM
bandidolenny's Avatar
I've said it before and I'll say it again... Don't ya just love those 1995 model year GM computer systems?
Old Jul 29, 2009 | 07:52 AM
cage47's Avatar
cage47 is on a distinguished road
I had one of those OBD 1.5 units in my Grand Am. Is your computer in the engine compartment or in the dash? If it's in the engine compartment then it's obdII. Best way to tell is to look on the radiator shroud. In the upper right corner there should be a box that says either OBDI or OBDII compliant. But the computer location is the best indicator.
Old Jul 29, 2009 | 05:25 PM
Biohazed's Avatar
lol Cage, not true .. mine is ODB 1.5 AND the computer is under the hood. But Actron makes a decent scanner that is ODBI and II compliant and won't brake the bank.
Old Jul 29, 2009 | 05:50 PM
cage47's Avatar
Everything I read the OBD1.5 computers were in the dash. Even kyle said the same. But they did some funky stuff with 1.5 so who knows. But my 95 GA was an OBD1.5 and the computer was in the dash like the OBD1.
My haynes book says the same.
Old Jul 29, 2009 | 07:35 PM
Biohazed's Avatar
Picture is worth a thousand words! and mine is ODB 1.5
Old Jul 29, 2009 | 07:50 PM
cage47's Avatar
Are you sure it isn't OBDII?
Old Jul 30, 2009 | 02:32 AM
rowe's Avatar
nice pic of the comp biohazed,,mine isnt there,must be in the
dash.and thanks for the tip on the actron,was lookin at those
and seemed that would have been one of my choices.
reason im going to get this is im having probs,when my truck warms
up it is dying on me,no certain amount of time but it could
go a mile or two or it could go 8 or 10 miles and then it just dies out
and wont start back up for a few minutes,,then when it does i have to rev
it a little,,then it will run fine till the next time it dies.
got me stumped,,,when i got this blazer i had to put a fuel pump,,,then a spider in it with new inlet fuel lines,,and seein i was shelling out so much money
i figured i would do a tuneup,plugs,wires,cap.rotor,,and it still has some kind of mis
and smell of unburned fuel,,also noticed a slight tap in the top end,not sure if that
is whats causing the mis thou,,its a mess this truck,,,but i would at least like to
stop the sudden dying in the middle of the highway crap,,,LOL.its dangerous.
