OBD II contact where?!?!?
Old Apr 13, 2008 | 03:36 PM
Mickeymouse's Avatar
Mickeymouse is an unknown quantity at this point
Default OBD II contact where?!?!?
Hi again...
Could anyone tell where the OBD II contact is located??? Can't seem to find it or am I just dumb???
Thanks Michael
Old Apr 13, 2008 | 03:56 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: OBD II contact where?!?!?
The ALDL connector is located on the lower driver's side instrument panel sound insulator (hush panel). That's the black plastic panel bolted to the very bottom of the driver's side of the dash. The connector has 16 pins for OBD II and is very close to the park brake lever.
Old Apr 14, 2008 | 02:35 PM
Ok thanks...
I just wanna check if I have any trouble codes...???
Regards Michael
Old Dec 8, 2008 | 04:44 PM
matclark's Avatar
matclark is an unknown quantity at this point
Default OBD I contact ?!?!?
sorry to bother you, but i need some help! how do i check the tccm codes with a obd1 12 pin connector? or can i?
i have a 1994 s10 blazer4x4, i can not get it to go into 4hi. i can hear the tccm click when i try tp put it in both 4hi and 4lo,,i can hear the transfer case motor engage and disengage,,but when you go to 4hi it sounds as if it goes straight to 2hi,,i took the switch out of the dash and used a jumper (just lightly touching the contacts) to activate the transfer can,,with switch or with the jumper it works the same,,so i am ruling out the switch,,
Old Dec 8, 2008 | 05:13 PM
rriddle3's Avatar
Default RE: OBD I contact ?!?!?
matclark,
Rather than attach a post to an eight month old thread, please start a new thread in the appropriate section. You will probably get more responses.
rowe
22
Dec 10, 2018 10:45 AM
petrolhead
Jun 17, 2015 02:36 AM
chipb21
Jan 11, 2015 06:06 PM
george154302
Aug 30, 2012 06:37 AM
mdehoogh
Jan 22, 2012 12:35 PM
