OBD Plug
Old Feb 5, 2008 | 02:46 PM
knaillhard's Avatar
knaillhard is an unknown quantity at this point
Default OBD Plug
Hi
I recently got a hold of a 95 model S-10, and now I am considering buying a ODB code reader.
My question is; where is the plug located? Does anyone have a picture of the placement?
I have been looking under the dash, but I cant seem to find it...
PS: Sorry if my English isnt perfect, I am Norwegian
Old Feb 5, 2008 | 04:18 PM
Default RE: OBD Plug
Welcome!
It should be on the under dash hush panel on the driver's side. Attached is an image showing its placement.
Please be aware that '95 was an inbetween year for the on-board-diagnostic setup. It is commonly referred to as OBD1.5 as it has elements of OBD1 as well as elements of OBD2. This can make code reader selection tricky. If you have some code readers in mind, we can look them over for you and let you know if it will work.
Hope this helps!
[IMG]local://upfiles/667/603F6C7096674FFFB53CCD89C5A08326.gif[/IMG]
Old Feb 5, 2008 | 10:51 PM
knaillhard's Avatar
Ok, I´ll see if I cant find it this afternoon.
I was looking at this; http://www.myscantool.com/, it said they had used it successfully on the `95, but after som reading here I got a bit unsure...
Maybe someone has one they could recommend?
Old Feb 6, 2008 | 01:04 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
It seems that that tool will not work for your application. also you should get rid of the comma in the link above as you have to post it into the browser bar and delete the comma for it to go to the webpage.
Old Feb 6, 2008 | 01:08 PM
knaillhard's Avatar
Sorry about the comma, I had just woken up
Guess I`ll keep on looking then. Found the plug though.
Old Feb 8, 2008 | 12:05 PM
FreeBird's Avatar
FreeBird is an unknown quantity at this point
Any of the OBD II readers from Equus Innova (3030, 3100, 3120 which does OBD I and II) would work. They are fair priced also. Starting at about $50 and up. The 3120 runs about $200 (avg. price), but does both styles of OBD. Just really depends on if you do more OBD II or if you do a mix of OBD I and OBD II.
futuredoc
Oct 7, 2024 06:14 PM
4.3l trouble
Apr 7, 2019 06:54 PM
rowe
22
Dec 10, 2018 10:45 AM
Geeky121
Jul 3, 2015 05:05 PM
boulonman
Mar 5, 2007 05:10 AM
