occasional vibration in front end 2001 blazer 4 wd
Old Feb 17, 2024 | 04:05 PM
don james's Avatar
don james is on a distinguished road
Question occasional vibration in front end 2001 blazer 4 wd
I t has done this twice at 40 to 60 mph on turns both times......it sounds like just hitting the edge of the rumble bumps.......the first thing that I thought was a failing front ujoint .........I jacked it up and ujoints seemed tight no grease leaks.....bearings and rotors were only slightly warm......wheels tight on hubs.........this never happens just driving around town......just the two times at hiway speeds..........I pulled over both times to make sure nothing was loose or tires tires flat..........turned around both times and headed home at hiway speed with no noise??????.......it has 160000 well maintained miles..........and easy use.........never any other suspension problems
nickcageislame
Nov 1, 2015 12:21 AM
GaryF2012
Dec 28, 2011 05:27 PM
MrJP
Oct 23, 2009 07:33 PM
ksibley603
Jan 9, 2008 10:11 PM
jagblazer01
Sep 6, 2006 04:45 PM
