Odd rear glass gremlin?
Old Dec 24, 2019 | 11:38 AM
Zenith's Avatar
Zenith is on a distinguished road
Default Odd rear glass gremlin?
Thought I would post first to see if the community had any feedback before I tear the dash apart.
I recently had the dash out, replaced heater core, and removed the previous owners install of a remote starting system while I was in there. Whoever installed it did a nice job as no wires were cut, only tapped into. Very easy, clean removal and taping the wires back up.
Problem since doing that, is my rear glass release button stopped working on the tailgate. My remote and dashboard release buttons work fine. I replaced the rear release button with a used one and then purchased a new GM button and still not working.
Car electrical is not my strong point. Any pointers or suggestions would be greatly appreciated before I start dismantling everything again.
Happy Holidays all.
Old Dec 30, 2019 | 05:39 PM
Tajohns34's Avatar
That is a tough one. If your dash button works it shouldn't be anything you did. Check the wiring inside the tailgate.
Old Dec 30, 2019 | 06:51 PM
GeorgeLG's Avatar
What year is the truck?
George
Old Dec 31, 2019 | 07:24 AM
Zenith's Avatar
George
2001 ZR2 Blazer. Haven't really had time to look at it yet. It's just a very weird coincidence that it stopped working immediately after removing the remote start system.
Old Dec 31, 2019 | 09:16 AM
GeorgeLG's Avatar
Ok, let’s get to work. Let me confirm:
The rear glass unlocks and locks properly from the driver door, the passenger door and the remote but the rear glass does not lock or unlock from the rear gate button. Is that correct?
George
Old Dec 31, 2019 | 12:18 PM
Zenith's Avatar
George
Correct.
I also just replaced the rear gate button twice, the most recently with a new ac delco.
Old Dec 31, 2019 | 12:25 PM
Zenith's Avatar
The only other thing that comes to mind is, when I had the steering column plastics covers off doing the uninstall of the remote starter system, I noticed there is a small 2 wire pigtail with a white connector (small gauge green wires) tucked up under my ignition switch, it was not plugged in anywhere and I ignored it as perhaps a piece of my wiring harness that maybe was for the audio controls on a steering wheel that mine does not have.
Now, I'm wondering if maybe that pigtail needs to be plugged in as perhaps the remote starter system may have needed that as a bypass? Just thinking out loud here.
Old Dec 31, 2019 | 12:53 PM
GeorgeLG's Avatar
Open up the rear gate to get access to the wiring for the lift gate button. First determine if you have 12V on the orange wire at the button/switch. If you do then short the orange wire first to the lt blue wire and then to the white wire to see if either the lock or unlock functions work.
George
Old Jan 1, 2020 | 01:01 PM
Zenith's Avatar
George
Thanks George, I'll report back tomorrow, got a day off then.
Old Jan 2, 2020 | 12:33 PM
Zenith's Avatar
George
No power to the orange wire at the release button/switch. Nor does either connector in the access hole have power to the orange wire coming from the wire loom. I'll trace that wire back under the carpet up into the dash and see what I find.
