Odometer window and gear selector window problem
Old Sep 7, 2016 | 05:45 PM
ChevyHead's Avatar
ChevyHead is on a distinguished road
Default Odometer window and gear selector window problem
Hi again. I've got a little head scratcher for the forum and Blazer buffs. I have an '03 LS 4 door,4x4,4.3L V6, auto transmission. For the past few months, I've had a SES light on and my brake and ABS lights flash on and off, sometimes just flicker like there's a connection loose somewhere, or sometimes they just stay on for a while, then go out for a while. I know the popular fix is to have the EBCM soldered, I just haven't got to it yet. Today, however, on the way to work, my Odometer readout and Gear selection window flickered, then went blank for a few miles, then came back on and haven't done it since. Could these two light issues be related? What would cause the odometer and gear window to do that? Any ideas what I should look for? Any help would be greatly needed and appreciated and thanks in advance.
Old Sep 8, 2016 | 06:20 AM
Tajohns34's Avatar
I had a similar issue a while back, my gear selector was black. It turned out to be a broken wire at the neutral safety switch. You could always start there.
Old Sep 9, 2016 | 08:24 PM
ChevyHead's Avatar
Would the NSS be in the steering column of my Blazer?
Old Sep 10, 2016 | 06:35 AM
LannyL81's Avatar
Suggest pulling the instrument pod out and cleaning the contacts as this does sound like a loose or dirty electrical connection regarding the gear and odometer displays. There could also be a wire or wires in the steering column that are out of place and have had the insulation rubbed through from the steering wheel turning.
Time to spend some quality time with the Blazer, good luck and let us know what you find.
Old Sep 13, 2016 | 07:46 AM
Tajohns34's Avatar
The NSS is on the side of your transmission.
Old Sep 21, 2016 | 08:00 PM
awesomeamerican1's Avatar
awesomeamerican1 is on a distinguished road
Big box on the drivers side of transmission is the nss
I also have the same issue with the sporadic flashing tranny gear selection crap. Pretty sure mines related to a bad ground somewhere between the body and block/frame, just haven't gotten around to it yet. Look up a wiring schematic and start having fun tracing that crap back!
Attached Thumbnails Odometer window and gear selector window problem-4l60e-2ds.jpg
slickwilly1976
Apr 25, 2011 11:00 AM
SoapyTheCat
Nov 30, 2010 07:21 AM
Shaggy
Jul 30, 2010 09:03 AM
er.rigney
Jun 3, 2009 09:16 PM
Bl4z3r
Feb 10, 2009 08:39 PM
