oem fog light switch wiring
Old Nov 6, 2010 | 06:52 PM
streblo's Avatar
Default oem fog light switch wiring
Ok, so heres the details.
2000 blazer without stock fogs
got an oem switch with the stock fog switch
know that to wire it in the stock way you need to play around with the bcm.
Im putting on aftermarket fogs on the bush bar.
So basically quick question to make things go a little smoother, what are the wires that come off the back of the fog light switch? (ground, illum?..etc). I plan on just wiring them into the relay for the aftermarket fogs...if possible, and if anyone has done this how much fun was it?
Old Nov 6, 2010 | 08:22 PM
The factory fog light switch is just a momentary switch. You would need to use a latching relay inorder to use the switch like you propose.
Old Nov 6, 2010 | 08:45 PM
streblo's Avatar
Got one of those, just dont know what each wire does from the switch
Old Nov 6, 2010 | 08:47 PM
Ok. Just figured I would mention it before you got too far in.
See the attached connector view:
Old Nov 6, 2010 | 09:31 PM
streblo's Avatar
Wicked thanks!!! this is a winter project for me to dink around with for some time, have the old relay and switch from a set of lights but i dont really like them so still deciding on some new fogs to mount on the bush bar!!!!
Old Nov 6, 2010 | 09:35 PM
RangerG's Avatar
I have the exact same thing. No factory fogs, but bought a panel with the switch, and fogs on my bushguard that need wiring. I'm to lazy to take my dash apart again though...
Old Nov 6, 2010 | 09:48 PM
streblo's Avatar
ya mine all came from a fried riostat (i have no idea how you spell it). dash takes no time to take apart to get to it, but when i put it in i picked up the switch from a junker and took the wiring plug for it as well, so i saudered in some longer wires and have them lieing empty down by the floor so i dont have to take the dash apart again.....im just way to lazy to run the wires through the firewall...so this could turn in to a several month project. haha
1fastls1ss
Jun 7, 2013 11:41 AM
bryanbc
Feb 26, 2013 10:57 PM
manekDC2_
Nov 5, 2010 02:55 AM
TimmiT
Mar 10, 2008 12:01 AM
