Oil cooler line replacement advice..
Old Oct 22, 2016 | 08:34 AM
jkyle187's Avatar
jkyle187 is an unknown quantity at this point
Default Oil cooler line replacement advice..
Im going to replace my (#9, 15194579) Oil Cooler Hose Assembly. Do I replace the (#11, 15759293) Oil Cooler Hose Seal and the (#6, 25013767) Oil Filter Bypass Valve too? If so, is there an oil seal between the hose assembly and the block? if so can someone tell the part number? any tips to an easy change?..Thank you in advance...Tony
Old Oct 22, 2016 | 09:42 AM
Vahomboy's Avatar
Vahomboy is on a distinguished road
I didn't replace #6 but replaced both hoses. I bought from AA though. They lasted about a year before they started to leak again. Then I did the hose mod and still good today. New gaskets came with the hoses I bought from AA (Dorman brand).
Old Oct 22, 2016 | 09:48 AM
jkyle187's Avatar
Default mods
I will be doing the hose mod..any suggestions on what type and size of hose to use?
Old Oct 22, 2016 | 10:10 AM
newguy's Avatar
I just did mine and used the same hose yhat came with it. Bought new and modded that one
Old Oct 22, 2016 | 11:42 AM
jkyle187's Avatar
Default clarifification
I will be using an old hose from the pull a part and doing the hose mod..but i still need the info on the seals and valve.
Old Oct 23, 2016 | 05:36 AM
newguy's Avatar
Best thing I can say is if your doing this on a budget just take a good look at the old ones. maybe you can get by.
Old Oct 23, 2016 | 07:05 PM
jkyle187's Avatar
not trying to do it on a budget..trying to do it right the first time....still need answer to the seal and valve question....
Old Oct 23, 2016 | 09:02 PM
LesMyer's Avatar
There are three valves. Two in the remote oil filter adapter and one in the block. Two are the same and the other is different pressure. Don't mix them up or put the wrong ones in. One in the remote adapter is a real pain. Is there a reason why you think they are bad or contaminated? I replaced all three of mine due to metal in oil. If you haven't had a bearing problem I would leave them alone. Seals on both ends of the main oil cooler hose are the same and are available from Doorman.
https://blazerforum.com/forum/2nd-ge...ves-4wd-90057/
stonecoldsteele
Nov 6, 2016 03:23 PM
Newbeme
Feb 8, 2008 10:42 PM
dublin1
Sep 8, 2007 08:12 PM
FImports
Dec 6, 2006 08:28 PM
Jetfixer
Jul 11, 2006 05:02 AM
