Oil Filter Access Panel screw Replacement for 2001 blazer/bravada?
Old Mar 12, 2014 | 03:16 PM
bigtone23's Avatar
bigtone23 is on a distinguished road
Default Oil Filter Access Panel screw Replacement for 2001 blazer/bravada?
Does anyone have the part # or know of a good replacement for the lock screw that is used for the oil filter access panel? My original fell off, I tried using a larger metal screw, but it backed out and was lost. The local scrap yard I use to get parts doesn't have any of these panels with the screw. I am wanting to just find the original part and replace it.
The panel is just swinging open, and I hear it's not a good idea to let it do this since it apparently interferes with proper cooling and can cause the engine to run a little warmer than it should.
Old Mar 12, 2014 | 03:23 PM
bigtone23's Avatar
Think I found the pin on ebay. We'll see...
Old Mar 27, 2014 | 11:11 PM
bigtone23's Avatar
Yep, It works!
Retainer Pin
Part #15041267
762mm
Mar 28, 2021 01:54 PM
ntjoe
Jan 1, 2015 06:41 PM
jcortes63
Nov 3, 2008 11:10 PM
chevyman30571
Feb 18, 2008 10:35 PM
