Oil filter lines- adapter to line gasket
Old Jan 28, 2013 | 03:02 PM
Diaita's Avatar
95 is a changeover year for Blazers, I've read people having issues getting the correct parts for them. Glad you got'r figured out.
cleburne red's Avatar
OReillys also carries them at $10.99. The o rings worked fine on the line to filter fittings. Just the line to adapter had a problem. I probably tightened them too much. Either way, I would rather go back with what was on there originally.
Old Jan 28, 2013 | 04:53 PM
The Dorman 66201 gaskets are correct. They are used at the remote oil filter block under the radiator. The O rings should not be used, they will blow out as there is nothing to retain it in position, as you already found out
DouglasWillard19
Nov 6, 2013 03:25 PM
shamipacqu
Feb 18, 2009 05:37 PM
shamipacqu
buck
Feb 16, 2009 01:22 PM
birchy82
Aug 6, 2008 02:44 PM
