Oil Filter Location
Old May 17, 2005 | 07:06 PM
Charidy's Avatar
Charidy is an unknown quantity at this point
Default Oil Filter Location
I have a 99 4door Chevy Blazer. I am wondering were the oil filter is located.
Thanks once again for you help.
Old May 17, 2005 | 10:37 PM
shawn_dh's Avatar
shawn_dh is an unknown quantity at this point
Default RE: Oil Filter Location
I have a 98' S10 P/U and the oil filter is located just infront of the transmission. It can be approached from underneath the vehicle from the driver/front side. I would try looking there since our vehicles are very similar.
Old May 18, 2005 | 12:03 AM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
blazers have them in front of the engine underneith. there is a door on the plastic cover under the engine that says "oil filter access" on it. turn the screw 90 degrees counter-clockwise and flip down the door. its right above it.
Old May 18, 2005 | 11:44 AM
Charidy's Avatar
Thank you! I will check it when my husband gets home. I am the smaller one so I get to be the one that crawls under.
Old May 19, 2005 | 08:18 AM
zero psi's Avatar
Retired Admin
ha ha lucky you! luckly you wont have to crawl far, its right behind the bumper.
Old May 19, 2005 | 09:52 AM
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
ORIGINAL: zero psi
Does that apply to older models too? I did an oil change and I had to pull off the air filter cover and bunch of stuff to get to the oil filter. I didn't think about looking underneeth, so if that is easier...
Old May 19, 2005 | 12:00 PM
Patrick's Avatar
Patrick has disabled reputation
some have remote oil filters too.
Old May 20, 2005 | 12:32 AM
zero psi's Avatar
Retired Admin
im not sure about all older ones, but i did an oil change in a syclone and it was mounted behind the radiator support right on top. kinda dumb in my opinion. you get oil all over the place.
Old May 20, 2005 | 09:30 AM
m00nwater's Avatar
well mine is right beside my air filter in a dumb spot...it's right behind the headlight right overtop of the driver's side tire basically...it's a pain in teh *** to change because you have to pull everything off...I was just hoping that maybe there was an easier way. Everyone used to make fun of my Volvo, but man, it was easy to work on...so much room in under the hood!
Old May 20, 2005 | 03:14 PM
Patrick's Avatar
that was what i thought...quite a few of them have the remote filter system, which is evidently supposed to keep the oil cooler, since it is away from the engine. but you would think that if it was that great of an idea, all of the performance cars would do that
