Oil Filter Location
Old May 20, 2005 | 03:58 PM
xjeepguy's Avatar
xjeepguy is an unknown quantity at this point
Default RE: Oil Filter Location
I have a 94 with the remote oil filter located behind the air filter assembly, and the thing that makes the oil run cooler is that the oil line actually runs through a section of the radiator. I can usually just wind out the two thumb screws, and tilt the airbox up enough to wind off the filter. I havent found it to be too bad. I took it apart to change the head gasket, and I was quite suprised to find three different fluids running through the radiator. It was no fun to take out, I can tell you that.
Old May 25, 2005 | 12:13 PM
Charidy's Avatar
Charidy is an unknown quantity at this point
UPDATE: Zero Psi your right. I did not have to crawl far. I really cant tell yall were it is or what is next to the oil filer. I just followed Zero Psi directions and they led me right there. Thank you!
ORIGINAL: zero psi
blazers have them in front of the engine underneith. there is a door on the plastic cover under the engine that says "oil filter access" on it. turn the screw 90 degrees counter-clockwise and flip down the door. its right above it.
Old May 25, 2005 | 09:47 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
it was nothing. glad i could help.
igs4dragon8
Oct 3, 2012 10:27 PM
wyoboss
Oct 10, 2011 06:01 PM
ncplumber
Jan 20, 2008 01:24 PM
comart45
Feb 4, 2007 11:53 AM
meglog
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Feb 27, 2006 03:17 PM
