oil leak 2wd 2004 blazer
Old Jan 2, 2011 | 12:57 PM
tmar04's Avatar
tmar04 is on a distinguished road
Default oil leak 2wd 2004 blazer
just bought 04 blazer, 2wd, and have a small oil leak around rear of eng. naturally, it is in area of rear main seal leak, but could be running down, or back, from another leak. any ideas where to look, that might be common leak problem for this model. 2wd so no cooler lines. thx to all.
Old Jan 2, 2011 | 01:01 PM
rriddle3's Avatar
Check oil pressure sending unit at the top rear near the distributor. A leak there can run down the back of the engine. There is an inspection plug on the bell housing you can remove to see the flex plate. If the rear seal is leaking there will be oil on the plate.
Old Jan 2, 2011 | 02:11 PM
tmar04's Avatar
Talking 2004 oil leak
thanks so much. I will check it out. Have a Happy New Year.
Old Jan 2, 2011 | 03:11 PM
I had what I thought was a rear main seal leak on my old '00 Bravada. It ended up being loose pan bolts.
fletch125
Dec 24, 2014 12:53 PM
MTopper
Jul 12, 2011 12:19 AM
dukester1351
Jan 3, 2011 07:14 AM
sanger
Jun 28, 2010 08:38 PM
SureShot
Tires and Wheels
Nov 9, 2009 04:04 PM
