oil lines
Old Aug 1, 2016 | 08:09 PM
blazinjay83's Avatar
blazinjay83 is an unknown quantity at this point
Default oil lines
I have a 2005 4wd 2dr Jimmy....I noticed while doing an oil change that the 2 oil lines that connect right where the oil filter screws on are cracked on the rubber portion.
What are these lines called ?
Looks like I can unmount them pretty easy from oil filter side....the back looks kind of tight....is it a pain ?
Old Aug 1, 2016 | 10:10 PM
Trelane's Avatar
Trelane is on a distinguished road
Sounds like your talking about the oil cooler lines, If so then ya
they are a pain. If I remember correctly you have to disconnect
driver side motor mount and raise the motor an inch or 2.
Not fun as I recall
Old Aug 2, 2016 | 06:12 AM
Vahomboy's Avatar
Vahomboy is on a distinguished road
I changed mine one time without disconnecting the motor mount (still a PITA) but eventually did the hose mod. Well worth the time to do so. No leaking issues since.
Old Aug 3, 2016 | 06:10 PM
TMM217's Avatar
TMM217 is on a distinguished road
You can run without them too. A pf47 filter is required and a coupling to do so. I run synthetic and Im not worried about the oil coking with any excess heat.
RSDEVIL
Dec 12, 2015 06:12 AM
cahlersmeyer
23
Nov 10, 2011 09:23 PM
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
