Oil pressure drops to 0 on turns
Old Jun 29, 2010 | 09:01 AM
sh1520's Avatar
sh1520 is an unknown quantity at this point
Post Oil pressure drops to 0 on turns
Have a problem that started a couple days ago. I was coasting down a hill doing about 45-5-mph with my foot OFF the gas. Noticed my 'check gauges' light come on. I saw the oil pressure gauge at ZERO! I put my foot on the gas and it went back up to normal-or 40 on the gauge. Now it happens if I'm slowing to go to a stop, or turning. Whats the problem? How do I rectify this? Thanks all!
Old Jun 29, 2010 | 09:13 AM
You really should try to verify the factory electronic gauge with a mechanical gauge.
Old Jun 29, 2010 | 10:09 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
I would check my oil level first. Then look for leaks at the sender. It's usually located at the back of the rngine on top next to the distributor.
Old Jun 29, 2010 | 02:00 PM
vandelayindustries's Avatar
vandelayindustries is on a distinguished road
This. The electric sending units are notorious for failure.
Old Jun 30, 2010 | 01:33 AM
4x4BlazerZR2's Avatar
4x4BlazerZR2 is on a distinguished road
Finally, a thread I can help with! You need to check your oil level immediately. It has been my experience that you (and I) are approximately 3 quarts low when this occurs. Also, if I'm not mistaken, when you turn to the right, the gauge goes to zero as well.
Old Oct 4, 2010 | 01:42 PM
blazinloud's Avatar
that sounds bang on, mine did the exact same thing
c40788
Mar 23, 2014 08:52 AM
abig84
14
Jun 7, 2012 04:21 PM
RyansChevy
19
Apr 13, 2011 06:42 AM
new2blazers
Jul 24, 2010 03:59 PM
rooster
Jun 7, 2007 08:40 AM
