Oil pressure gauge goes from normal to zero periodically.
Old Jun 10, 2010 | 02:52 PM
bulldogauto's Avatar
bulldogauto is on a distinguished road
Default Oil pressure gauge goes from normal to zero periodically.
Hey everyone, on my 2001 chevy blazer v6 the oil gauge periodically drops to zero then will go back to normal. It will do this several times while im driving and it will sometimes stay all the way at zero for a long time before it comes back. Besides a faulty oil pump what else could cause this to happen? Could it be a cracked gasket? Or any other ideas would be great thanks.
Old Jun 10, 2010 | 06:08 PM
blazin8556's Avatar
blazin8556 is an unknown quantity at this point
the oil pressure sending unit.
Old Jun 10, 2010 | 08:04 PM
Yea i was thinking of that aswell but i think it might be intigrated into the pcm. Do you have any idea where that might be besides the computer?
Old Jun 10, 2010 | 11:28 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
It could be the sending unit, unless you hear the engine sound different at 0psi. If the engine changes sound when its at 0psi there could be something floating in the pan that plugs the pickup sometimes.
Old Jun 11, 2010 | 06:35 AM
rriddle3's Avatar
Hook a mechanical pressure gauge to the connector at the oil pressure sending unit (top rear of the engine near the distributor) and verify the pressure readings. If the mechanical gauge shows normal, then the problem is with the sending unit.
Old Jun 11, 2010 | 06:37 AM
Nvidia78's Avatar
Nvidia78 is on a distinguished road
Mine does the opposite, when fully warmed up and driving it goes from like 45 psi and pegs all the way up and goes back to where it should be, I am not to worried about it since its either a loose connection in the cluster or the oil pressure sensor acting up
Old Jun 11, 2010 | 11:49 AM
jigger's Avatar
jigger is on a distinguished road
Over fill on the oil can make the gage drop to 0, the crank whips the oil and the pump sucks up the bubbles. I know of this happening to some one b/c he got tired of having to add oil to his oil burner all the time.
Old Jun 11, 2010 | 07:43 PM
cool guys thanks for all the advice im ganna try and check out all of these.
the86ali
May 22, 2015 01:39 PM
the86ali
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Apr 19, 2015 10:54 AM
MKelley
Mar 25, 2013 07:11 PM
castnhope
Mar 5, 2012 05:10 PM
boscoedoodle
Nov 24, 2009 10:56 PM
