Oil pump removal
Old Dec 12, 2007 | 05:29 PM
gtseater's Avatar
gtseater is an unknown quantity at this point
Default Oil pump removal
I have a 95 s10 blazer 2WDanyone know to take the oil pump off without taking the motor out ??
Old Dec 12, 2007 | 06:17 PM
Default RE: Oil pump removal
You may be able to jack the motor up and remove the oil pan. Once the oil pan is off, you can remove the oil pump. You just have to be careful when you put the new pump back in that you get the drive engaged on the bottom of the distributor properly.
Old Dec 12, 2007 | 06:20 PM
rriddle3's Avatar
Unfortunately I think you have to lift the engine on the 2wd's because the frame member is in the way of removing the oil pan. 4wd's don't have to lift it.
Old Dec 12, 2007 | 09:39 PM
Hanr3's Avatar
^ I think you got that backwards.
Old Dec 13, 2007 | 10:19 AM
rriddle3's Avatar
Ummm, I don't think so, at least not according to the Chevy shop manual.
Old Dec 13, 2007 | 10:23 AM
That shop manual didn't happen to mention removing the front axle as a single step at the beginning did it? For both the 4wd and 2wd, the motor mount cross bolts will have to be removed and the engine jacked up as high as it can go (the transmission will hit the underside of the truck). This will be the most room you can get to take things apart.
And this is only speaking of the '97 (I think) and older trucks as newer than that and they have a cast aluminum oil pan that requires the transmission be free of the engine for removal and installation due to the structural nature of the pan.
Old Dec 13, 2007 | 10:37 AM
rriddle3's Avatar
Oh, yeah, it specifies removing quite a bit of the underside of the truck on the 4wd, but does not mention lifting the engine like it specifies for the 2wd. It's the dvd version of the manual. I was thinking you have a copy of that, also, don't you?
Old Dec 14, 2007 | 09:50 PM
Hanr3's Avatar
I have never seen the DVD version.
I only know from taking hte engine out whats in the way of the oil pan.[8D]
Old Dec 14, 2007 | 10:29 PM
gtseater's Avatar
Thanks For all your help . I may take the body and lift it off the frame so i don't have totake the motor out
Old Dec 15, 2007 | 04:44 PM
Hanr3's Avatar
Lifting the body wont do any good.
The oil pan is trapped between the engine and the front axle/front frame cross member.
The front axle has to come out, and the engine has to go up. OR take the engine out. Its not that hard, just time consuming.
To get the engine out you only need to disconnect teh tranny, exhaust system, fuel lines, electrical harnesses, cooling system, and take the a/c and power steering units off the engine. Tehy can lay in the truck out of the way. It's much easier to take the hood off too.
BouncingRadical
14
Nov 27, 2015 12:30 AM
lowgear
Jul 11, 2015 05:30 PM
SummerWren
Jan 3, 2013 06:47 AM
todaresqSL2
Nov 10, 2008 01:47 PM
irata
Jul 7, 2007 03:36 PM
