Oil Stabilizer
Old Jan 13, 2023 | 03:28 PM
Jmack's Avatar
Jmack is on a distinguished road
Default Oil Stabilizer
Do you use an oil stabilizer for preventing future leaks? I used it in my previous cars that were not blazers. When i had a leak I used it and it stopped leaking. I read in an oil forum it said they don’t recommend using it unless you have already have a leak. Also my mechanic said he doesn’t recommend Lucas transmission fix fluid unless your transmission is slipping.
Old Jan 13, 2023 | 08:25 PM
AJBert's Avatar
'If it ain't broke, don't fix it" has been my motto for many years. Just do the regular maintenance. If you end up getting a leak on whatever system, best thing to do is fix it. However, I do understand that a simple leak is not always an easy fix. I've used that stuff twice, once as a temporary fix, and another as a fix as I couldn't find the leak. Never did find that leak but the additive appeared to work. Never did leak again. I've never used it as a preventative measure for a leak that might happen.
medicineman2011
Dec 26, 2017 01:56 PM
1sexyblzr
Jun 15, 2010 01:54 PM
freonchill
Apr 14, 2009 10:45 AM
MagicMan
Apr 30, 2008 12:49 PM
mdemers2006
Aug 10, 2007 11:39 PM
