Oil and Trans Cooler Line Connections at Radiator
Old Dec 10, 2014 | 11:20 AM
LesMyer's Avatar
Default Oil and Trans Cooler Line Connections at Radiator
Anything at the radiator fittings need replaced for the 4 lines when going back together, other than the retaining clips? This is a 2001 4WD.
Old Dec 10, 2014 | 09:42 PM
You can use thread sealer on the fitting, and there is an O ring inside the fitting. Needs to be oil rated for the oil cooler lines, and transmission fluid rated for the trans lines, (different O rings).
Old Dec 10, 2014 | 10:49 PM
LesMyer's Avatar
gotcha - thanks!
SoullessNihilist
Jul 7, 2014 08:05 PM
igs4dragon8
May 14, 2013 09:52 PM
NYC86ZC
Dec 12, 2010 08:21 AM
gstxtt
Jun 24, 2009 12:08 AM
Jetfixer
Jul 11, 2006 05:02 AM
