ok I'm stumped
Old Jun 3, 2012 | 03:24 PM
lndianScout's Avatar
lndianScout is on a distinguished road
Default ok I'm stumped
when I purchased my blazer I knew the speedo wasn't working, so I figure no problem, I've replaced the VSS on my other 2 so why should this one be so different
wrong..
first thing I did was change the VSS, still no speedo or odometer, then I removed the cluster looked for bad solder connections resoldered a few, reinstalled it, same no speedo or odemeter.
so the whole time the transmission shifts prefect, I went out and tested the cruise control it's working great, so the vss has to be working
am I looking at a bad stepping motor in the dash for the speedo??
Old Jun 3, 2012 | 05:23 PM
duxtoyz's Avatar
duxtoyz is on a distinguished road
what year blazer? it could also be the connection at the trans case, unless thats the VSS ur talking about. if not, try there......its a boxy looking thing that has ur speedo cable attached to it thats attached to the trans case. if its broke or sticky ur speedo or odometer wont work.
youngbloodsno111
Mar 23, 2019 07:00 AM
black99gm
Oct 31, 2009 06:13 PM
Joey P.
Dec 21, 2006 09:23 PM
pinkituscaderro
Jul 5, 2006 04:28 AM
94_4.3dago
29
Feb 8, 2006 07:21 PM
