Okay folks..need some serious help with an '98
Old Jul 23, 2013 | 09:03 PM
qc013330's Avatar
qc013330 is on a distinguished road
Default Okay folks..need some serious help with an '98
Hey all. Im having some serious problems with my '98 s-10 blazer. I noticed it was having some transmission issues, and had the transmission rebuilt after finding out it was bad. However, I noticed after picking it up that it was no better than before. After a typical reaction of "those dang mechanics didnt fix squat", I calmed down and got the trouble codes checked. It was displaying codes P0101B, P0147B, P0171B, P0452B, and C0281. I was told I should replace the mass air flow sensor, and that that would help all but the last problem. So, I did..and the blazer is still shifting like crap. Now it's displaying codes P0101B, P0102B, P0102, and C0281. Anyone have any ideas what the problem could be??
Thanks a ton!
Old Jul 23, 2013 | 09:21 PM
warthogdriver's Avatar
check the mass air harness for cuts/issues.
check vac leaks?
i think the c0281 is brake switch related...check that under the dash behind brake pedal.
others may chime in. good luck
Old Jul 24, 2013 | 09:09 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
check the air plenum (peice between MAF and intake) for cracks. The C0281 is a brake switch code, do your brake lights work? When the 4.3 runs poorly the trans often feels like it is shifting poorly, but in reality its not its doing as it should but the engine isnt keeping its end of the bargain.
SOunds like a vacuum leak of sorts is going on
butters
Sep 10, 2010 05:40 PM
Doverman454
Aug 14, 2010 11:46 PM
jstein
Tires and Wheels
Aug 20, 2009 07:32 AM
James_Inman
Sep 5, 2008 12:11 AM
bowanna03
Oct 1, 2006 03:10 PM
