old school rad fit?
Old May 6, 2020 | 01:38 PM
bravo99's Avatar
Default old school rad fit?
I have an extra 91 s10 4x4 TBI 4.3 radiator. Will it work in front of my 99 4.3 Bravada awd Vortec? she done sprung a leak....notsobravo.
Old Jun 14, 2020 | 02:58 AM
jimspahr@msn.com's Avatar
I don't know. How I research this problem is to look up both the 91 and the 99 S-10 models in a net catalog like Rock Auto and look at the same rad. with the same options and then compare the two part numbers. If they are the same part nos , then yes, they should swap. Don't forget the Engine oil cooler and the trans cooler---you must have the same coolers and the same fittings on both for the swap to work !
Old Jun 14, 2020 | 10:51 AM
bravo99's Avatar
thank you sir good to know! not sure I've ever seen the engine oil cooler be part of the rad before... isn't that a good way to get a false oil coolant mix that's not Lim related?
Old Jun 14, 2020 | 05:31 PM
Think of a rad inside a rad... if you look at Christine's thread of her installing one inside her aluminum rad, you'll get a good idea the inners.
Old Jun 14, 2020 | 07:00 PM
Old Jun 15, 2020 | 12:25 AM
bravo99's Avatar
thanks guys!
nc95blazer
Nitrous, Super Chargers, & Turbos
Aug 19, 2019 08:57 PM
sean485
Nov 7, 2010 01:34 AM
91Blaze
Feb 11, 2010 08:44 PM
deanosride
May 18, 2009 12:13 PM
TorqueBoy11
Feb 28, 2009 07:55 PM
