one scary window
Old Dec 9, 2009 | 03:56 PM
deerboy's Avatar
deerboy is on a distinguished road
Default one scary window
So, a mystery to wake you up ! 04, 2 dr. blazer elec pass window, works fine in the driveway, though finishes the closing with a slight bump at the end of travel....not really noticeable, but different than the clean travel on the driver side. Get on the highway at 70 or so....put the window down and then up....runs smoothly til the last 1nch or two...hesitates and then a let-loose BANG and closes tight. And I mean a BANG. This guy must be hanging up somewhere til the motor overpowers and the hand up lets go.... Am I on the right track ( no pun ) and anyone know definitively what may be the issue. I can't believe it is the regulator per se . Thanks for any assist. Dave
Old Dec 9, 2009 | 04:45 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
Could be the pop rivets that hold the motor on are loose/missing. Loose is a common problem. Could be one of the brackets to a window track is busted. Pull the door panel off and get looking.
Old Dec 10, 2009 | 09:29 AM
dman001948's Avatar
dman001948 is an unknown quantity at this point
When I'm going down the road at 80-85 mph and I roll up my windows, they will pop also, Its always done that (2000 LT 4x4) I think its just the vacumm that is created. When at slower speeds everything is fine except once in a while my driver side window will not work, I just kick the side panel if driving or open and shut the door and its off and running again. I figure a bad spot on the drive motor...
Old Jan 31, 2010 | 02:56 PM
deerboy's Avatar
Thanks for the hint, but think both windows would be a problem. Hope someone can really help here........it is really scary when it frees up with a monster bang !!
Old Jan 31, 2010 | 03:21 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
take your door panel apart!!!! we cant diagnose it from guesses.
matthewcarter1014
Jun 2, 2008 09:30 PM
94blueknight
Jan 29, 2008 07:30 PM
bdscholes71`
Oct 7, 2007 02:59 PM
TripleBlackBlazer
Sep 5, 2007 04:55 AM
sasquatchfound
Jul 19, 2007 10:14 AM
