Only driver door switch works the power windows...??
So I did some searching and a lot of past threads point to bad contact within the switch itself...??? But all three...??? Just like the title says, only the drivers door switch works ALL of the windows. I find it hard to believe all three other doors need switch replacement.... Thanks for any ideas...!!
Edit: The similar thread link at the bottom after I posted showed me some threads pointing to the child lockout switch... I'll give that a try and report back.
I'm going to have to google that word bc I have no clue what it means.
I do know however that these door lock sliding things are a FPITA.
Edit: Ahhhhh they go back NP on the locking position.
Ahhhhh then Thank You. It surely is.
Still so much more that bothers me on this poor truck. Yesterday the drivers door hinge was squeaking so I sprayed it w WD40 and today the grommet that holds the pin tight is now missing half of itself. A loose door that doesn't close right is the result, but hey @ least I fixed a few other things as well while in there messing w window switch today.
CPLSeraphim
07-15-2015 07:50 PM
ciggabuzz
06-16-2014 05:17 PM
shotnva777
09-20-2011 07:42 PM
