only starts with use of starting fluid
Hi! This Blazer runs fine once started. Problem is it will not start unless we use starting fluid, turns right over and all is fine. Starting fluid must be used for each startup, vehicle warmed up makes no difference. This is a '98, 6 cyl, auto with 4 WD. Any ideas? thx!
Try stepping on the gas as you crank it. A little throttle adds air to the mix. full throttle on crank is a clear flood mode. NO injector pulse so no fuel spray from injectors. Check your fuel pressure and make sure it is with in spec. if is is supposed to have 55PSI and only has 45 it will run but not start easily. Also the engine will run OK once running. Fuel systems work with PSI & volume. we don't measure volume of flow but it is the more important factor in the running of engines. you can't have one without the other but if either is down it's in a bad way. go to Airtex's web site and check out the videos. it's great info...
Tranzman
Tranzman
Saw this thread thought you may figure out the issue with this.
https://blazerforum.com/forum/engine...g-fluid-84541/
thx Tranzman. The problem has progressed. Now if it starts using spray it may keep running when put in gear it may not.
My daughter, her truck, tells me her boy friend and a friend of his replaced the fuel pump several months ago. So pump should not be the problem. Going to do suggested tests anyway to try and eliminate bad pump.
From what you describe, chances are pretty good that you've got a worn out pump. Check the link that tranzman posted. If you have questions, just ask. The fuel delivery system is simple and quick to accurately diagnose. Aftermarket pumps should be avoided, especially Airtex. Use AC Delco or Delphi only on this engine. Yup, it'll cost more, but you won't have to replace it again any time soon. They're good for 100K miles... Aftermarket pumps: some don't even make it out of the box!
camohunter
Mar 26, 2020 03:42 AM
BrinkDiamond
Mar 2, 2014 03:50 PM
Doctorvette
Nov 5, 2012 11:57 PM
W_evo8
Aug 10, 2009 06:35 AM
bjam2
Dec 3, 2005 12:39 AM
