Oops
Old Oct 30, 2009 | 09:49 PM
blazin_j's Avatar
blazin_j is on a distinguished road
Default Oops
So my battery was close to dead so I took it out and brought inside and went to hook it up to a battery charger, and I accidentally put the negative clip on the positive terminal and vice versa without the charger plugged in. There were some sparks but I got it off quickly. So should I put the battery back in and turn the key to the on position to see if I have power and didn't mess up my battery? Do you think it's still safe to charge? Thanks.
Old Oct 30, 2009 | 10:13 PM
old skool luvr's Avatar
it'll take a hell of a lot more than that to wreck your battery. just put it on charge-the right way-and she'll be good to go, if the battery is in a state to take a charge (regadless of what you just did).
i've never seen a battery charger do that before when it was unplugged.
Old Oct 30, 2009 | 10:35 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
The spark was most likely just some circuit in the charger that doesnt like being connected backwards so it drew power. If it wasnt plugged in polarity should be fine and the battery should be good. You could always pull out a multimeter before charging it and make sure the voltage is still good.
Old Oct 30, 2009 | 10:55 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
I doubt you hurt the battery other than it's pride...... The charger though? Heck, when a battery is low enough it sparks even when you hook it it right.
Old Oct 30, 2009 | 11:00 PM
blazin_j's Avatar
Awesome, thanks a lot guys. How long should I charge it at 2 amps? Overnight? It has 2 amps, 16 amps and start for options. Thanks again.
Old Oct 30, 2009 | 11:26 PM
ABN31B's Avatar
If you want to hurt your battery rub steel wool on the terminals. if anything changes, throw it at you open fuel tank
Old Oct 31, 2009 | 12:28 AM
blazin_j's Avatar
I think I'll pass.
Old Oct 31, 2009 | 11:05 PM
overnight (at least 12 hours), and then let it "stand" for 1/2 hour before checking the voltage, but it should be fine after that.
Old Nov 1, 2009 | 01:18 AM
blazin_j's Avatar
Thanks a lot Old Skool, Will do. Hopefully the beast starts. So many issues, but I still love her.
Old Nov 1, 2009 | 07:13 AM
kinda like women. she can bug the s**t outta us about the amount of time we spend fixin' our Blazer's, but we still luv them-the women i mean, hahahaha!
LagWagon
Mar 4, 2011 07:43 AM
zule13579
Jan 16, 2011 09:38 AM
97blazer617
Sep 17, 2009 11:37 PM
chipperi
Mar 31, 2008 01:56 PM
bitbandit
Oct 1, 2007 09:38 PM
