oops...rear shock replacement
Old Sep 12, 2009 | 06:36 AM
97blazer617's Avatar
97blazer617 is on a distinguished road
Default oops...rear shock replacement
so im changing my rear shocks...and 1 of the clip things,(where the 2 bolts go), broke from being so rusty. the other one is fine and will screw in. but with the broken clip the second one will not go. where can i find this clip thing...i checked autozone and they dont have it. if you dont know what im taking about...its one of those clip things that come with new speakers. its so the screw has somewhere to grab thread with instead of just going straight through. will the dealership have it. i dont feel like going to the junk yard...its been raining in MA for the past 2 days. thanks for any info. and ill do a DIY when i remove the other shock if its not up yet.
Old Sep 12, 2009 | 09:43 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
A dealer might be able to get the part, otherwise it would probably be a DIY part or a junk yard part.
Old Sep 12, 2009 | 09:50 AM
amazinnblazin's Avatar
amazinnblazin is an unknown quantity at this point
Check your local salvage yard, the dealer is only gonna rip you off... Sounds like a good thing you took off/checked it! Would suck to find out on the road!
Old Sep 12, 2009 | 02:23 PM
tom09's Avatar
tom09 is on a distinguished road
just drop a 5\16 bolt down through the hole and put a nut and lock washer on dont use a lock nut it will be to hard to hold the top of the bolt 8 mm will fit through also
Old Sep 12, 2009 | 04:42 PM
abig84's Avatar
Yea just put a nut and bolt if possable. That's how my 93 is set up
Old Sep 12, 2009 | 10:54 PM
BusaJoe's Avatar
BusaJoe is on a distinguished road
If you go to a parts store that knows what they are selling, NAPA or Car Quest. I used to sell them in the HELP line. You can get them anywhere that sells parts.
Old Sep 13, 2009 | 08:44 AM
i kind of made my own clip. but did not tighten to my liking. i will try the bolt thing. am i putting the bolt going down or going up?(thread part going up or thread part going down?) thanks for the help guys.
Old Sep 13, 2009 | 09:28 AM
abig84's Avatar
probably doesnt matter as long as theres enough room above the tower to the bolt dont hit the body. might have to do going upcause your probably gonna have to leave it on the socket to get it up there with the shock in place and will be a pain to try to start the nut from the bottom. see whatever is easier
Old Sep 14, 2009 | 07:59 AM
tom09's Avatar
use a 1 inch bolt and go down it isnt really that hard
Old Sep 17, 2009 | 11:37 PM
PHATSPEED7x's Avatar
PHATSPEED7x is on a distinguished road
It's a pretty standard speed nut. Most auto stores will have them.
Dadatone
Sep 16, 2012 06:15 PM
ComputerNerdBD
Suspension Tech
Nov 1, 2009 02:23 PM
blazin_j
Nov 1, 2009 07:13 AM
chipperi
Mar 31, 2008 01:56 PM
bitbandit
Oct 1, 2007 09:38 PM
