Open Diff Out - Limited Slip In
#31
You're not slow. You're meticulous, lol.
If that friction modifier smells half as bad as the Ford stuff, I know exactly what you mean. I don't even like to open the cabinet where we keep that stuff at work. Even in sealed bottles, it smells awful.
#32
Meticulous...???....perhaps....but also got ahead of myself.
I got the OEM ring gear onto the Dura Grip, back into the housing. Took over an hour to get the right shims, have a backlash of 0.0075"...which is tighter than what the open-diff was originally, but looser than what I just took out. I tried to use the original shims, just would not go. So then I put the cover on...got ready to fill...and that is when it hit me that I did not check the pattern.....crap!!
Oh well....at least I had not put fluid back in yet.....
#33
Also, make sure you have plenty of carrier bearing preload. I've never heard of carrier bearings failing from too much preload. If you don't have enough, try adding a small amount of shim to the side opposite the ring gear to help loosen up the backlash a little at the same time.
#34
That was my thinking as well.....so I decided to not take the cover off....filled with fluid. Put the drums/rotors on. Still on rear jack stands, started engine, put into Drive and listened. Only noise I heard was from the calipers as I had not put any lug nuts on....drums/rotors were a bit loose. Did the brake on / off couple of times....put into Reverse.....all seems to be good. Put the anti-sway bar, rear tires and got the spare tire back into place. Went for a very short drive...like 200 feet which included a circle....still no abnormal noise. Will do more slow driving around when I have more time, need to get it up to temp, before I call it good.
Later
Later
JODYM
01-23-2009 05:06 PM
