Out in Africa, I need a miracle - Blazer 4.3 LT
Old Apr 12, 2009 | 05:30 AM
shanegroening's Avatar
shanegroening is on a distinguished road
Default Out in Africa, I need a miracle - Blazer 4.3 LT
Hi Folks, I'm new to this forum and the Blazer community.
I recently purchased a 2000 Blazer 4.3 LT at an auction and I cannot get it to start unless I pour fuel directlly into the throttle body!
Out here in Swaziland, at Africa's southern corner, there is no support or service for my new baby!
These are my "symptoms":
a] the "check engine" light remains on
b] the engine turns when the ignition is started
c] there is fuel all the way through the fuel line up to the fuel throttle body
d] the engine starts if fuel is poured directly into the throttle body
I have:
e] replaced the fuel pump
f] cleaned the petrol tank
g] checked the fuel line to the throttle body
If you have a fuel circuit diagram or any advice you can share or threads you suggest I follow, I'd appreciate your help.
Thanks
Shane
Old Apr 12, 2009 | 06:07 AM
kiwiblazer's Avatar
Hi Shane.
Welcome to the forum.
Vasbyt ou maat, someone with the technical knowledge will pop along soon. They'll probably need a code to be read from the on board computer but I'm not sure if anyone, least of all in Swaziland, will be able to do that for you.
Where in Swaziland? I lived in Malelane (Kruger Park) many years ago (1970's). Also used to look after the admin for a haulage company in Big Bend, Matsapha, Mhlume & Simunye (from the Jo'burg office).
Old Apr 12, 2009 | 10:07 AM
bandidolenny's Avatar
Damn... and I thought I was far from help when broken down out in west Texas! Do you have a fuel pressure gauge to verify pressure from the pump? How about a scanner to retrieve codes from the computer? You really need to see what the computer is saying. Could be either the spider or connections at the pump. Anyone else?
Old Apr 12, 2009 | 01:27 PM
AJBert's Avatar
Try changing out the fuel filter. If the tank needed cleaning and the filter was never replaced, that could be your culprit. Getting a pressure guage on there will go a long way in the trouble shooting arena.
Old Apr 13, 2009 | 07:02 AM
Originally Posted by kiwiblazer
Hi Shane.
i live in manzini also used to work in BIG bend at the sugar mill
Old Apr 14, 2009 | 01:40 AM
kiwiblazer's Avatar
I worked for the haulier that hauled the cane to the mill back in the '70's & '80's. Not sure if they're still there. I left S.A. in 1992 & have never been back - never will.
Got your problem sorted?
jadamrust
Apr 9, 2012 06:50 PM
xgiovannix12
Jan 23, 2012 07:24 PM
groundedmk
Jan 22, 2012 11:23 PM
weigtmarek
Jan 14, 2012 12:42 PM
markchilman
Nov 27, 2011 03:09 PM
