Outside Air Temp Sensor
Old 06-02-2010, 08:38 AM
Fusefinder's Avatar
Fusefinder is on a distinguished road
Default Outside Air Temp Sensor
I read in one thread that it was behind the grill, either I missed it or didn't know what I might have been looking for. Any help on a more specific location?
Thanks
Old 06-02-2010, 11:34 AM
I have posted pictures in numerous other threads... If I have time later, I'll see if I can dig one up. In the meantime, combining search terms together with a '+' between them will get better search results.
Old 06-02-2010, 11:59 AM
84BlazerS10's Avatar
You might try searching by it's technical name It's a ambient temperature sensor.
Old 06-02-2010, 04:48 PM
Mammys Car's Avatar
Mammys Car is an unknown quantity at this point
Default Ambient Air Temp Sensor
Don't know if your year is the same but on my 2000 Blazer the sensor is in front of the A/C condenser near the upper passenger side corner, just behind the grill. Almost impossible to see until the grill is removed. Easy to do; grab the grill and pull forward. The sensor is black rectangular device about 1/2"X1/4" as I recall. Electrical plug on short pigtail. Easy to replace.
Hope this helps.
Old 06-02-2010, 07:58 PM
Fusefinder's Avatar
Thanks I'll try that in the morning. Running on gen power now bad storms this evening. But yes the description does help. Thanks all.
Old 09-08-2010, 06:58 PM
johnnybgoods's Avatar
johnnybgoods is on a distinguished road
Default Ambient temp reads OC
I have the same problem. Temp display reads OC. Can someone help? It is driving me NUTS.I have 2000 Blazer LT
Old 09-08-2010, 07:10 PM
A search for "ambient+temp+sensor+resistance" with an author of "swartlkk" returns THIS POST. The information posted there can be used to test your sensor.
Removing 'resistance' from the search term returns more threads and this one should be particularly helpful:
Temp not working on Compass/Temp Display
Old 11-11-2010, 10:12 PM
cb6's Avatar
cb6
cb6 is offline
cb6 is on a distinguished road
AMBIENT AIR TEMPERATURE GAGE SENSOR REPLACEMENT
REMOVAL PROCEDURE
Remove the radiator grille.
Lift the temperature sensor upward in order to remove the temperature sensor.
Disconnect the electrical connector.
https://blazerforum.com/forum/members/cb6-25832-albums-ambient-air-temperature-2995/
Last edited by cb6; 11-11-2010 at 10:15 PM. Reason: add link because image insert dosnt work
Old 11-11-2010, 10:17 PM
This thread is over 2 months old I would assume he found the problem.
Old 11-11-2010, 10:37 PM
69chevelle's Avatar
69chevelle is on a distinguished road
REMOVAL PROCEDURE
https://blazerforum.com/forum/album.php?albumid=2995
trying to make a how-to:P think it needs to be a bit more detailed and it can be stickied
Step 1.) Remove Grille by pulling forward
Step 2.) Left up on temp sensor
Step 3.) Unplug temp sensor by lifting tab and pulling out connector
Step 4.) Install in reverse order
something like that with detailed pictures might be stickied, your pics don't work for me.
thanks to this I realize my temp sensor is improperly installed, as it's mounted horizontally
Quick Reply: Outside Air Temp Sensor
