In over my head. Please help!
Old Apr 7, 2018 | 11:25 PM
Mr. Joe's Avatar
Mr. Joe is on a distinguished road
Cool In over my head. Please help!
This isn’t the first time, just the first time with this Blazer. Was my mom’s Blazer, she passed, I bought it. I know it had good maintainence - 50,000 miles, ton of oil leaks though. I’ve put 45,000 on it and it has a lot more leaks so I decided to r&r it and during the “&” part, I’d change the oil pan gasket, timing chain, oil pump, etc... . In the process I also changed the distributer cause the bearing in it was shot. First “r” was straight forward, second “r” tough! Primed the motor, all looked good, hooked up coil wire and it started but ran bad, real bad. Set motor at TDC, rotor was way off, not on the 6 at all. Played around for a real long time until I got it sat, hooked it all back up and she would not start, she made a sound like may be I was180 off. Played around for a real long time again until the distributer sat again. This time for sure I was 180 off. Fixed that. Ran like crap again. Buddy came over with a scanner it showed crankshaft sensor. Put in good new sensor with new pig tail. Now it starts, runs smooth for about 30 - 60 seconds and turns off. What is going on man?
Old Apr 8, 2018 | 07:13 AM
newguy's Avatar
When you put in a new Crank sensor you need to do a crank sensor relearn, which requires a high end scanner, Auto zone walmart advanced auto wont work. After that you need to do a camshaft relearn with same scanner
Old Apr 8, 2018 | 10:11 PM
Mr. Joe's Avatar
That’s it? Thank you newguy! I’ll find a shop with a scanner that’ll reprogram tomorrow. Thanks again.
Old Apr 8, 2018 | 10:34 PM
LesMyer's Avatar
Cam sensor retard is an adjustment, not a relearn. Should be 0 +/- 2 degrees.
Crank sensor relearn is for misfire detection. Won't actually cause a misfire, but it can make you PCM think it has a misfire and turn on the SES lgiht..
Although these things need to be done/checked, I don't think it's the cause of your problem.
Sounds to me like distributor may still not be in right or you have a fuel pressure problem. If it's not setting a P1345, then your distributor is in on the correct tooth.
Old Apr 9, 2018 | 07:46 PM
Zenith's Avatar
Zenith is on a distinguished road
Would the crank sensor re-learn be necessary after replacing the timing cover but re-using the old crank sensor?
I just did LIM gaskets, head gaskets, New distributor, wires, plugs, coil, Spyder Injector and timing gear set.........
I re-used the crank sensor....starts and idles with a small intermittent miss gets worse as the engine temp increases.
Didn't mean to hijack this thread.
2001 Blazer 4X4
Old Apr 10, 2018 | 08:28 AM
LesMyer's Avatar
2001 Blazer 4X4
It's supposed to be done every time the crank sensor is disturbed at all. But again, failure to do a crank relearn does not and will not cause an actual misfire. However, the PCM may think there is a misfire, when there really isn't one present (false misfire). During a crank sensor relearn, the PCM stores information regarding the normal signal of your particular crank sensor, installed in your particular engine. A variation on this signal is interpreted as a misfire. Change or disturb the crank sensor and all bets are off for accurate misfire detection.
As for your felt misfire, check your cam sensor retard. Should be 0° ± 2°. If that's OK check fuel pressure. Start a new thread if problems.
Old Apr 10, 2018 | 08:56 AM
Zenith's Avatar
Perfect, thanks so much, and good luck to Mr. Joe
Old Apr 12, 2018 | 07:29 PM
Mr. Joe's Avatar
Default Newguy please read. Still in over my head
Newguy, if you’re out there I wanted to let you know that I took her to a shop for the relearn and they told8 me I had the reluctor wheel on backwards. I just pulled the timing chain cover off and the wheel is broken! The collar that slides over the crankshaft was broken off all the way around. Have no idea how. Think it was on right, collar was toward the engine. Gotta find a reluctor wheel now. Chevy said it is a discontinued item but they could find one. It’ll take a week or 2.
Old Apr 13, 2018 | 02:34 AM
newguy's Avatar
Glad you figured it out, good luck and let us know how it comes out
1998mom
Jul 30, 2013 12:03 AM
deekisses
May 17, 2012 11:31 AM
KyFritz02Xtrm
Sep 26, 2009 12:48 PM
sktdarkstar8
Sep 5, 2006 09:47 PM
