Overheating
Old Sep 1, 2011 | 10:07 AM
FreaKariDunk's Avatar
FreaKariDunk is on a distinguished road
Default Overheating
I am wondering how I can troubleshoot that problem? Where would you begin? I dont know if it is the water pump.
Old Sep 1, 2011 | 10:44 AM
chris015's Avatar
Alrighty...u have to tell us what you have, if it does it moving,sitting at a redlight,or air conditioning on,etc etc...Lots of factors.
Old Sep 1, 2011 | 01:58 PM
warthogdriver's Avatar
x2...without some details it could be anything.
Old Sep 1, 2011 | 02:17 PM
Senshi09's Avatar
Senshi09 is on a distinguished road
x3 it could be anything from a blown intake/head gasket to simple as needing coolant in the radiator. But without details we can't help you at all. Have you checked your coolant level? Is it full or empty?
start troubleshooting by checking your coolant level.... thats the first thing you should do. From there let us know whats going on by telling us if you have coolant, no coolant, if its overheating while driving or at a stop/idling.
Old Sep 1, 2011 | 05:42 PM
It is when i drive it, the tempture gets up high like 240. also, it seems like I am going though a lot of antifreeze. Sorry for being vague.
Old Sep 1, 2011 | 05:48 PM
i would say...lose of antifreeze points to leak.
and i am guessing since you didnt mention puddles that is either burning off or you have an internal leak.
exhaust look cloudy?
oil look like oil and not milkshake?
"a lot of antifreeze.." like a gallon a month...a week? (hope not)
smell of antifreeze when you are stopped?
spark plugs look "white" or wet at all?
info...we need some more.
not being picky...just need it to help you out.
little things could point us in one direction or another.
Old Sep 7, 2011 | 10:33 PM
00blazer13's Avatar
00blazer13 is on a distinguished road
Default overheating
You can also check under the oil fill cap. If there is moisture in it you may have coolant leaking into the engine. Like the other guys said, more info would be helpful. Does the coolant fill the overflow tank, then spill onto the ground?
Old Sep 8, 2011 | 12:42 AM
xgiovannix12's Avatar
Check the oil asap please
If it looks milky you have a blown head gasket dont run it till fixed
Old Sep 8, 2011 | 05:18 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
You can also get coolant into the crankcase through a failed intake manifold gasket.
Old Sep 8, 2011 | 07:48 AM
As Kristoph stated, the LIM is a definite possibility. It is FAR more common to have a failed LIM dump coolant into the oil than have a head gasket failure on these engines.
A quick compression test would tell you whether you had a head gasket problem.
bigjames
May 22, 2011 03:12 AM
NOs
Jan 22, 2010 12:47 PM
cmh_20
Nov 21, 2009 11:39 AM
getblazed00
Jun 14, 2006 01:18 AM
sectshun8
Feb 27, 2006 01:54 PM
