Overheating on Interstate
Old Sep 15, 2009 | 10:02 AM
BigFitz's Avatar
BigFitz is on a distinguished road
Default Overheating on Interstate
1996 Vortex V6 4 Wheel Drive Blazer
The temp. is fine when I am idling or driving in town. When I get on the gas on the interstate it starts to overheat. So as long as I don't get on the gas I am fine. I already changed the thermostat and radiator cap. And I had the radiator flushed. What do you think it can be? I need some help.
Thanks
Old Sep 15, 2009 | 10:24 AM
dman001948's Avatar
dman001948 is an unknown quantity at this point
I really wish I could help you out, I'm having the same problem, posted it here and never got a answer.
I have replace the rad, both hoses, the theromstat, the rad cap, but this time and it might seem strange but, When I replace the Rad cap (16lb) I also added a can of Seafoam to the crankcase and it appears to be running cooler. I drove down the interstate on a test drive for about 15 miles and it didn't even reach 210 and I live in AZ where it gets hot, hot here.
Now was it the Cap or the Seafoam or both? But so far so good.
Old Sep 15, 2009 | 02:25 PM
Confuused69's Avatar
Confuused69 is on a distinguished road
Ever think about replacing the water pump while you replaced the radiator and thermostat? You should. You might have air in your system. What you should do, since it is 13 years old, you should pull the clutch fan. Take out the water pump, and flush the engine. Then put a new water pump on and gaskets. And make sure you dont get air in your system. That should solve your issues.
Old Sep 15, 2009 | 02:44 PM
BigFitz's Avatar
So you don't think I should try the bottom radiator hose?
Old Sep 16, 2009 | 02:31 PM
dman001948's Avatar
I would have replace the water pump "IF" I thought it needed to be replace, was not leaking, no movement as in looseness and the fan clutch appeared at that time to be alright. My radiator was leaking so I replace that and the hoses and the thermostat.
Everything ran well for about 6 months, then I notice the heat building up again on the freeway. So again I check everything out and replace the one I haven't done and that was the cap (it was orginal) and dump a can of seafoam in the crank. So far again everything is alright, when the water pump or fan go out and if I keep the truck for very much longer I will replace the items as needed.
The thermostat is one of those newer type that are made to release any air that might build up, but, I purge the system anyhow just to be safe.
Just for your info.
bigjames
May 22, 2011 03:12 AM
NOs
Jan 22, 2010 12:47 PM
cmh_20
Nov 21, 2009 11:39 AM
getblazed00
Jun 14, 2006 01:18 AM
sectshun8
Feb 27, 2006 01:54 PM
