Overheating Problems
Old Jan 6, 2018 | 01:19 PM
PAPaul's Avatar
PAPaul is on a distinguished road
Default Overheating Problems
Seen a lot of people over the years with over heating problems with their second gens. Seen that they replace the thermostats, flush systems, replace water pumps with no fix. Just want to mention all three of second gens that I owned had overheating problems do to a bad tension pulley assembly which would let the belt loose enough to slip on the water pump. Usually can hear the belts squealing or watch the tension pulley assembly jump while engine is running.
just my two cents worth of experience hope maybe it can help someone save a penny.
Old Jan 6, 2018 | 01:35 PM
Thanks for the post. I've started monitoring the "New Posts" section so I can gather new hints and knowledge such as what you shared.
I've replaced my tensioner a several years ago but now I am hearing a sort of squealing, a lower pitched one, that goes with the engine speed. It also only happens now and then.
I try to pop the hood and try to find the source but I cannot locate it. Also it often is gone by the time I get to the front.
BUT, I have noticed my tensioner oscillating/jumping back and forth while the engine is running. According to my manual, it is not swung out far enough to indicate a stretched belt though.
Perhaps what I'm hearing is originating with the tensioner?
Old Jan 6, 2018 | 05:45 PM
newguy's Avatar
I believe this is normal, both my blazes do this
Old Jan 7, 2018 | 08:36 AM
dlundblad's Avatar
dlundblad is on a distinguished road
I have a second gen Grand Cherokee and typically the source of this noise is actually the idler pulley bearing. You can buy a whole new pulley and bearing, but if you have a shop press, all you need is a 203ff alternator bearing and a little Loctite.
Interestingly enough, both my Grand and Blazer use this bearing. All parts stores have them.
Old Jan 7, 2018 | 09:10 AM
Mike.308's Avatar
If I seen a swinging serpentine belt, I'd remove it (3/8 release socket within a belt tensioner) and manually check for a worn off (loose) bearings. That would let me know whether the problem lays in a belt tension or a worn off bearing.
Just my 0.03$
Old Jan 7, 2018 | 10:07 AM
chevy2's Avatar
chevy2 is on a distinguished road
could also be a weak belt tensioner spring.
Old Jan 7, 2018 | 01:33 PM
Just my 0.03$
Thanks Mike. I can't believe I did not think to do that for myself yet! I'll try to get to that today.
iamchevyman5
Jan 6, 2014 01:44 PM
NOs
Jan 22, 2010 12:47 PM
cmh_20
Nov 21, 2009 11:39 AM
upblazer95
Apr 4, 2009 08:27 PM
michelleharris_mh
Nov 11, 2008 03:08 PM
