Oxygen Sensors
Old Mar 2, 2011 | 05:16 PM
Heffty's Avatar
Heffty is an unknown quantity at this point
Default Oxygen Sensors
My check engine light came on a while back. I got the codes ran and the shop told me it was my oxygen sensors. All four. How much should I expect to pay to have these fixed at a shop? I live in Calgary Canada.
Old Mar 2, 2011 | 05:34 PM
TouringMike's Avatar
TouringMike is on a distinguished road
Get another opinion.
It's very unlikely all 4 would go at the same time.
Parts cost is probably around $300.00 to $400.00 or more for the parts alone.Add 2 hours labor, and you'll get a round figure.
Old Mar 2, 2011 | 05:38 PM
jbsnowboarder16's Avatar
jbsnowboarder16 is on a distinguished road
O2 sensors are approximately $60 each here in the States. There is no reason to pay a shop to replace them IMO. It is a pretty straight forward DIY. If you do when the pipes are still warm, they will come out easier. There's a special socket that you can buy that has a slot in it for the wires and then a 3/8 drive for a socket that makes the job easier
Old Mar 3, 2011 | 11:15 PM
jaxgent's Avatar
jaxgent is on a distinguished road
I strongly suspect an intermittent oxygen sensor, should it become necessary to replace, is a penetrant product like WD-40 advised on a warm pipe?
Thanks
Old Mar 4, 2011 | 08:38 AM
ffox's Avatar
ffox is on a distinguished road
Replacing mine was one of the hardest jobs I've ever had to do on mine. The heater burned out on it so I decided to replace it. First of all it's very hard to get to, it's on top of the Y pipe right at the cat.converter. I went and paid $18 for a set of oxygen sensor wrenches (never start a job without the right tools) The first thing I did was heat it slightly with my torch, then sprayed it good with PB Blaster and let it sit over night, then I sprayed it again before I attempted to take it out. It wouldn't budge. Anyway I went through this routine for 2 days, spray, heat, groan, scrape knuckles. Rounded off oxygen sensor..Finally I ended up heating it (the pipe, not the sensor) a cherry red with my acetylene torch and taking a small pipe wrench and still had to put everything I had to break it loose. After I got it out I found that none of the PB blaster that I had sprayed on it had gotten to the threads because of the sealing washer on the sensor. And NO anti seize compound. Always put anti seize compound on them when you install new ones.
Old Mar 5, 2011 | 09:48 AM
Heffty's Avatar
Yeah I don't have tools or time to dick around. I was just thinking to take it in.
Old Mar 5, 2011 | 10:45 AM
Debonair's Avatar
Debonair is on a distinguished road
when i didnt have the time to do it i bought the O2 sensor myself and brought it in to have them do it. cost 40-50 bucks.
try rockauto.com to see some prices for sensors
Old Mar 5, 2011 | 08:36 PM
Jbyrd76's Avatar
Jbyrd76 is on a distinguished road
Default O2 problems also
Hey all i have recently had the same problem and bought a bosch O2 sensor that went after the converter.. i replaced it reset code and drove for like 10 miles and same code has popped again.. Any ideas would be much appreciated im thinking cat is clogged or maybe one in front of the cat is no good?
drin
Apr 26, 2010 02:10 PM
kimirwin75
Oct 20, 2009 08:32 PM
kbreck
Mar 25, 2008 08:57 AM
KA3AX
May 9, 2006 08:38 PM
swartlkk
Apr 24, 2006 02:37 PM
