P0128 Help
Where is the thermostat located on the 01 Blazer?
Its located on top of the engine in front of the intake. The housing that you remove to access it is black (at least on my 2000 it is). You have to drain a little (About 2 quarts) antifreeze out of the radiator so you don't spill it when you remove the housing. To get to the housing bolts, I found that removing the throttle cable brackets made it a lot simpler since they are in the way. Once you remove those, it is as simple as removing the housing, removing the old thermostat, putting in the new thermostat, making sure the housing surfaces are clean and then repeat the process backwards.
I was surprised there was no gasket for the housing, but I guess the rubber ring on the thermostat acts as the gasket.
If I just replaced the thermostat, how long should it take for the "Service Engine Soon" light to turn off?
if you replace the thermostat, and top off the coolant level, i would drive it to see if the temp rises to normal opperating temp, if it does you can clear the code by taking the negetive battery cable off and reinstalling it.
I already brought the car up to operating temperature with no issue. Removing the negative terminal will reset the codes?
yea, unhooking the battery will reset the Computer.
bulwaagh
10-11-2012 02:39 PM
