P0147 Code...running new wires?
Old Jan 20, 2008 | 10:23 PM
wankel7's Avatar
wankel7 is an unknown quantity at this point
Default P0147 Code...running new wires?
Ok, my 1995 Jimmy has had this intermittent code. I know its an emissions only code and does throw the car into limp mode. And I tried a new sensora while back and the code came back.
So, I am thinking wiring.
I really do not care about this CEL .... but now I am trying to sell it so I need to fix it .
Any idea where this rear downstream sensor's wires end up in the ECU? I would love to just run a new harness from the ECU to the sensor.
Is the ECU under the hood? Does anybody have pin outs for the ECU so I could just run new wires?
Thanks for any help!
James
Old Jan 20, 2008 | 11:56 PM
Chevy Lover's Avatar
Default RE: P0147 Code...running new wires?
Are you sure it's a code P0147. I don't see a code P0147. I can find a code P0141 that is a heated O2 sensor code.
You say you tried a new sensor wire....for what sensor?
Old Jan 21, 2008 | 12:01 AM
wankel7's Avatar
Same code this dude got...
https://blazerforum.com/m_83626/tm.htm
Maybe I should just try swapping sensors...seems much easier than running new wires.
James
Old Jan 21, 2008 | 12:30 AM
I don't know why you would run new wires. It sounds like an O2 sensor failure.
I also don't know what year truck the other post refers to. I was looking at codes for a '95
Old Jan 21, 2008 | 06:30 AM
Your '95 must be a late '95 to have codes like this. If it is, you may have 3 O2 sensors total. One directly behind the 'Y' in the y-pipe (B1S1), one directly ahead of the catalytic converter (B1S2), and one directly behind the catalytic converter (B1S3). If you have 3 total, then you can try swapping B1S2 to B1S3.
But if you have already replaced the B1S3 sensor, it may be wiring or the ECU itself. How long ago did you replace it and with what brand sensor? Did the new sensor cure the problem initially? If it did, then it could just be that the sensor was lazy from the start...
ned4spd8874
Mar 5, 2010 12:35 PM
rogggg1020
Sep 24, 2008 06:53 AM
blauer
Aug 28, 2007 07:17 AM
lylebig
Jan 2, 2007 09:03 PM
MeidleinA
Dec 19, 2005 10:05 PM
