P0155 code
Old Jul 15, 2008 | 08:14 PM
Aerojoe's Avatar
Aerojoe is an unknown quantity at this point
Default P0155 code
I just bought a 2001 xtreme blazer has 160k. I tuned it up and it runs great. I got a code p0155 heater malufunction bank 2 sensor 1. I replaced the pass side sensor before the Y with a standard brand green box. Never had a problem with their sensors. AC delco are hard to find in the stores everybody has that crap bosch stuff. Anyway the light didn't go off after I changed the sensor. Should it go off if the problem is fixed or must it be reset?
Old Jul 15, 2008 | 08:55 PM
Default RE: P0155 code
To start diagnosing this problem, I would have first swapped sensors side to side. If the code follows the sensor, then replace the sensor. Since we are past that, you have a decision to make. And that is is the new sensor good or is it a problem with the wiring.
Old Jul 15, 2008 | 09:12 PM
Aerojoe's Avatar
What I was wanting to know is should the light shut it self off or does it have to be reset. I still have the other sensor and can swap it but it is a little dark out now.
Old Jul 15, 2008 | 10:02 PM
It should go away if the fault is repaired. How long ago did you replace the sensor?
Old Jul 15, 2008 | 10:05 PM
Aerojoe's Avatar
I just changed it tonight. Bank 2 is the pass side correct? I have seen it refered to as the drivers side. I was always told bank one has cyl 1 and bank 2 has cyc 2 on it.
Old Jul 15, 2008 | 10:09 PM
You are correct. If the new sensor did in fact fix the problem, then the light should go out after 3-4 drive cycles.
ezblazer
May 19, 2013 07:42 PM
Warhead
Oct 24, 2011 03:56 AM
Brandie
Nov 1, 2010 06:34 PM
GREZ28
Nov 26, 2009 09:42 AM
