P0171
Old Jul 29, 2010 | 03:09 PM
sagoo33's Avatar
sagoo33 is an unknown quantity at this point
Default P0171
Hi,
I recently changed the plugs and leads, I didn't notice at first, but the control to change the direction of the fan/heater wasnt working.
After a day of driving the SES light came on and gave the 0171 code.
I found I had knocked off the vacuum hose which attaches to the hose going through the firewall into the cab.
I thought that would have fixed it as it the control appeared to work again (when the engine is cold). So I cleared the code. (The code was thrown again after driving another day)
After the engine has warmed up, the control doesn't work properly. I can move it onto the demister if I turn the blower off, change the direction and turn it back on, otherwise whatever setting it is on blows out of the face vents.
When the engine is cold and I change the direction, I can hear the vacuum hissing (the normal noise I have always heard) and changing. When it has warmed up, moving from the feet to the demister, there isn't a hiss but just a click.
I'm assuming that the code is to do with vacuum leak somewhere as opposed to the MAF sensor?
Im guessing I must have knocked another vacuum line somewhere.
The code suggests a leak downstream of the MAF sensor? Where is the MAF sensor so I can try and chase it out?
I definitely have a performance loss, there is a noise from the right hand side of the engine when accelerating hardish and fuel economy has gone down the drain.
Any thoughts would be appreciated!
Cheers,
Adam
kmartin
14
May 1, 2013 08:18 PM
hebelracing38
Jun 11, 2010 04:00 PM
Jonas
Jan 12, 2010 02:34 PM
97ssblazer
Sep 14, 2008 04:18 PM
