P0300 persists
Old Dec 3, 2017 | 08:26 AM
GreenBlazer2002's Avatar
Default P0300 persists
I've been using Dash Command to monitor the effects of the various upgrades/changes that I've made over time. I had misfire codes p0304 and po300 so I replaced the cap and rotor with AC Delco parts and while I did see the p0304 disappear, the p0300 persists. There seems to be a handful of misfie (10 or less) at various times on several cylinders. Is there a tolerance for misfires or will the code trip even if there's a single misfire detected? If I wasn't seeing them on the readout I wouldn't even notice them it runs so smooth.
Old Dec 3, 2017 | 05:17 PM
GeorgeLG's Avatar
CEL/code is set when the misfire threshold is exceeded, usually around 2% of the 200 revolution counter. Misfires are not counted outside of certain operating conditions such as deceleration.
George
Old Dec 3, 2017 | 06:41 PM
CEL was off today. Yet code is still stored. Weird.
marty68's Avatar
marty68 is on a distinguished road
chasing this P0300 myself... have you checked where your cam sensor retard is?
Old Dec 4, 2017 | 11:53 PM
Actually no. Where should it be?
Old Dec 5, 2017 | 07:42 AM
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
If your light is off you fixed it. The code will stay in memory for a while.
Old Dec 6, 2017 | 07:17 AM
LesMyer's Avatar
Originally Posted by greenblazer2002
actually no. Where should it be?
0° ± 2° You can clear the code with Dash Command and see if it returns. Note that with Dash Command you have to buy their enhanced PIDs for your particular vehicle, in order to do cam sensor retard ($10 + $10 more for enhanced PIDs).
Old Dec 7, 2017 | 04:30 AM
I have the enhanced pids. How do I manage cam retard?
Old Dec 7, 2017 | 09:36 AM
LesMyer's Avatar
Either add the GM.ENGINE.CMP_RTRD PID (found in General Tab) to the Data Grid or make a Gauge to display it.
Old Dec 7, 2017 | 05:21 PM
Got it. Thanks!
