P0449 and P0453
Old Feb 11, 2009 | 08:49 PM
Logan's Avatar
Logan is on a distinguished road
Default P0449 and P0453
Ok...ive been searching for a while and these seem to be related to the Evap solenoid above the rear end. I changed that and still getting these codes. Everything looks in good shape. What else could throw both these codes? Any help would be great!!
2002 GMC Jimmy 2 dr 4X4 SLS
Old Feb 12, 2009 | 09:48 AM
Rottidog's Avatar
Default RE: P0449 and P0453
I'd say google them but make sure you put it like GM P0449 otherwise you'll get lots of hits for Hyundi's, Toyota's etc etc, maybe try a GM site & search for codes?!
also try it as an O & a 0
Old Feb 14, 2009 | 10:02 AM
Logan's Avatar
Ive been doing that and it all seems to lead to that sensor that ive replaced. Donno what next to do.
Old Feb 14, 2009 | 10:44 AM
Rottidog's Avatar
A friend of mine often says "just because it's new doesn't mean it's good".
Might be a faulty sensor. Still got the reciept?
Old Feb 14, 2009 | 04:31 PM
P0449 is a code which gets displayed when the PCM checks the fuel tank vent solenoid circuit for electrical integrity. The value read by the PCM should be between 8V and 16V (basically battery voltage). The vent solenoid is not the same as the purge solenoid so it really depends on which one of these valves you replaced.
P0453 Explained
Old Feb 14, 2009 | 10:27 PM
Logan's Avatar
I replaced the one over the rear axle. Where is the other one? 3 sensors now...im not buyingg another. I Also cleaned all the electrical connections, and the filter. The light has been on for a few months now, and now that summers comming I want it fixed. I plowed all winter with the light on, but ill be hauling my derby car all summer. And I dont want anything afecting my fuel milage.
Old Feb 15, 2009 | 04:14 PM
The one above the rear axle is the vent solenoid. I would inspect the wiring to the vent valve starting by checking for proper voltage and ground at the valve itself. Then test each wire continuity to ground.
Old Feb 15, 2009 | 08:49 PM
Logan's Avatar
Ill get a voltage meter tuesday and check it. Family day is tomorrow, so everything is closed. Thanks for the help!
Old Apr 10, 2009 | 10:26 PM
Logan's Avatar
I finally figured it out... 2 of the 4 secondary O2 sensor wires were cut. I re-joined them and SES light is no more!!! I dont understand why I got those lights and not a secondary O2 light. Weird...
Old Apr 10, 2009 | 10:30 PM
Glad you got it fixed!
