p1345a code
Old Jan 13, 2008 | 11:23 AM
rob2129us's Avatar
rob2129us is an unknown quantity at this point
Default p1345a code
changed distributor and i now have p1345a code. on the genesis diagnostic computer i look at time retard or advance and it siad mine was -27 and the range is 0-2 hope my memory is right does anyone know how to retard or advance the timing it is a 2000 4x4 s10 blazer thanks all
Old Jan 13, 2008 | 01:43 PM
Default RE: p1345a code
P1345 - CMP/CKP Correlation
This code is popping up most likely because a crankshaft variation relearn procedure, sometimes referred to as a CASE learn, has not been performed. As the combination of the CMP and CKP sensor data is used for critical engine functions, the PCM has a correction factor to dial in their outputs precisely. By changing the distributor (and subsequently the CMP sensor I will assume), you have modified the sensors without recalibrating the correction factor.
Any Tech2 or equivalent scan tool should be able to perform the relearn procedure.
Old Jan 14, 2008 | 02:15 PM
rob2129us's Avatar
kyle that is exactly what it sadi but i am not familar enough with the genesis scan computer to to a case relearn can u tell me how do go about doing it?
Old Jan 14, 2008 | 03:33 PM
Every scan tool is different, you would probably have to consult the manufacturers documentation or directly via a phone call to see if it supports this operation.
In digging a bit deeper into this code, it may be solved with a case learn, but a scan tool to monitor the actual timing is necessary to determine if there may be a problem in the crank to distributor (crank to cam, cam to distributor) connection which could either be due to a stretched timing chain or a worn cam/distributor gear.
92s10Blzr
Dec 7, 2009 03:12 PM
nitro7
Dec 1, 2009 06:27 PM
98blazr
44
Aug 21, 2009 01:17 AM
lostatsea85
Jun 30, 2008 10:06 PM
lostatsea85
Jun 23, 2008 02:44 PM
