Parking brake help
Old Dec 31, 2010 | 06:57 PM
okiedoak20's Avatar
Default Parking brake help
Hey all, Happy new year, does any one know how to replace or adjust the parking brake switch that is attached to the parking brake pedal.
Thanks again
Old Jan 1, 2011 | 01:21 AM
mdehoogh's Avatar
The switch is located on the top of the parking brake assembly. There's a screw holding the switch to the assembly that will probably allow you to remove it but I'm not sure if you can buy just the switch. The lever assembly I bought (at the dealer) came with a new switch already attached.
The switch has a metal contact that points towards the lever. Bending the contact will adjust when the circuit is completed and when the light comes on.
You may need to unbolt the assembly in order to get a good view of the switch itself. I can post pictures of the assembly and switch if you would like.
Old Jan 1, 2011 | 01:28 PM
okiedoak20's Avatar
Matt, that would be wonderfull if you could send a few pics my way
thanks
Robert
Old Jan 2, 2011 | 09:23 PM
mdehoogh's Avatar
Here are some pics. There are three bolts holding the assembly to the truck. Two are visible and the third is partially hidden from view. I've outlined them in green circles below. You can see the socket resting on the third bolt in the second picture.
Once you have the three bolts removed, you should be able to move the assembly down far enough to see and adjust the switch contact. The cable can be difficult to remove from the lever because the jacket has three prongs that hold it in much like a fishhook. Unless you're replacing the whole assembly, you probably won't need to remove the cable
Bolts are outlined in GREEN and the switch is outlined in BLUE
Old Jan 9, 2011 | 06:11 PM
okiedoak20's Avatar
Matt, thanks a million, thoses pics really helped a lot.
Thanks again
Robert
audio junky
Feb 19, 2013 02:01 PM
hitmanK47
Dec 3, 2011 04:33 PM
dailydriver
Nov 19, 2010 11:26 AM
xderkax
Jan 14, 2010 11:38 PM
blackknight
Feb 8, 2007 03:27 AM
